View Poll Results: Does a looped fuel rail have a benefit?
Yes looped rail does have a benefit
83.33%
No looped rail does not have a benefit
16.67%
Voters: 6. You may not vote on this poll
Looped Fuel Rail?
Old Dec 4, 2013 | 10:17 PM
JesseJamessrt6's Avatar
Default Looped Fuel Rail?
After reading on the MBworld forum and talking with some of our members I wanted to see if anyone was interested in polling some feedback on what they thought about looped fuel rails and if they thought there was a benefit and why or not and why.
Claims have been made about equalizing fuel pressure across the two rails and from front to back of the rails as well as adding fuel volume in the rail.
This isn't necessarily with other fuel system upgrades.
Old Dec 6, 2013 | 07:54 AM
maxcichon's Avatar
Default Re: Looped Fuel Rail?
Some V8 and V6 FI engines are known for lean running cylinders at the front/opposite side from the fuel delivery site to the rail. Looping/increasing ID (capacity) fixes that issue just fine.
If ones fuel pump is up to the task.
Old Dec 6, 2013 | 08:12 AM
How hard could it be ?
A tee at the input connector, an additional hose to another tee at the fuel pressure test point ........
Sounds like a $50 kit .....
( Max, Grainger should have all the necessary parts )
Old Dec 6, 2013 | 11:42 PM
JEFASOLD's Avatar
I'm thinking the T at the test point but some way to connect it to the blind end , you want equalized flow. Have to look into this, maybe $75 or so.
Old Dec 7, 2013 | 12:36 AM
rmaier's Avatar
Subscribed see what you come up with.
Old Dec 7, 2013 | 09:27 AM
It has already been done and tested. 32Krazy had one on his car. I agree with Max on this one. I will add one not so much for performance but to equalize pressure in the fuel rail....
Old Dec 7, 2013 | 10:49 AM
grip grip's Avatar
I'm running the looped rail, and have been doing so for almost 2 years. I think of it as more a safety measure than a performance mod.
Old Dec 7, 2013 | 12:25 PM
Did you send in your rail to have it modified or just afterwards as a core? Did the TTM passenger side looped connection bolt right up to your Zex FPSS or did you have to put in some off set connections to make it fit out at an angle like that?
There is info about fuel rail mods but not much about increasing the fuel supply line, any links or experience with this?
Fuel Rail DIY - MBWorld.org Forums
pics are missing from the first post.
MBWorld.org Forums - View Single Post - Looped Fuel Rail Questions???
Custom fuel rail milled from aluminum!
Old Dec 7, 2013 | 09:19 PM
grip grip's Avatar
Everything bolted right up. As for the FPSS, I connected it by adding an inline manifold, which in this case was just a female to male connector with a 1/8 or 1/4 NPT for attaching the FPSS.
Below is a pretty version of the manifold, as opposed to the ugly brass fitting I found locally.
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
RacerXofFL
Sep 15, 2015 05:00 PM
81's
Sep 13, 2015 04:34 PM
RiderJC
Sep 7, 2015 11:19 PM
