mods install
Old Dec 30, 2013 | 08:40 AM
austinbarrylee's Avatar
Default mods install
Can someone please tell an estimate of hours to install NW Intake manifold, ECU, Pulley, PSK, Johnson IC Pump, Phenolic Spacers, SL55 fuel pump, AEM fuel regulator, Oversized Heat Exchanger
Separate,& Engine Coolant from Intercooler Coolant.
Thanks.
Old Dec 30, 2013 | 09:16 AM
bluecoupe's Avatar
Default Re: mods install
crank or s/c pulley?
Old Dec 30, 2013 | 09:20 AM
S/c pulley karmen
Old Dec 30, 2013 | 09:33 AM
grip grip's Avatar
I'd knock it all out in a weekend. A mechanic will probably charge around 10 hours.
Old Dec 30, 2013 | 09:48 AM
Default
Thanks grip grip. I found a mechanic that works for benz that does work on the side in his personal garage. I just want an estimate to tell him what others have done it in. The NOS is next
Old Dec 30, 2013 | 10:59 AM
velociabstract's Avatar
If he's real familiar with our cars and parts I'd estimate a day and certainly in a weekend. The front fascia needs to come off for the heat exchanger which makes the I/C pump easy too. The draining of the cooling system is messy. The pulley saver kit caused me a headache because I was clumsy that day. Fuel pump is easy as pie but I managed to soak my arm in gas. The intake manifolds are a snap if you've done them before. Please use stock gaskets with copper spray. I finally listened to others and ended my nightmare of leaky gaskets.
Les
Old Dec 30, 2013 | 11:39 AM
Default
[QUOTE=velociabstract;773732]If he's real familiar with our cars and parts I'd estimate a day and certainly in a weekend. The front fascia needs to come off for the heat exchanger which makes the I/C pump easy too. The draining of the cooling system is messy. The pulley saver kit caused me a headache because I was clumsy that day. Fuel pump is easy as pie but I managed to soak my arm in gas. The intake manifolds are a snap if you've done them before. Please use stock gaskets with copper spray. I finally listened to others and ended my nightmare of leaky gaskets.
Thanks for help. I know he works on slk32 a lot so I am thinking he is familiar with our motors. Copper spray is what I am hearing I am going to go buy some.
Old Dec 30, 2013 | 11:47 AM
grip grip's Avatar
Did you get longer bolts of accommodate the Phenolic Spacers? If they are stainless, I recommend you spray them with WD40 or anti-sieze prior to install to keep them from getting stuck. I'm not the first one to have one of the stainless bolts break off in the aluminum heads.
Old Dec 30, 2013 | 11:57 AM
Default
The spacer was used by another member who was selling them. I don't know if the bolts are included. I will have to contact them. If not where can I get those bolts.
Old Dec 30, 2013 | 12:01 PM
grip grip's Avatar
Needswings
PNA
Nov 12, 2020 04:44 PM
LE Cross
Oct 17, 2016 06:35 AM
MAXIMUM
Aug 4, 2015 11:04 PM
Jul 29, 2015 06:13 PM
3spencer3
Jul 24, 2015 01:08 PM
