Central locking system doesnt work with key
Old Jan 10, 2014 | 08:02 AM
Default Central locking system doesnt work with key
We have a member from Spain that is having an issue opening both doors with his key. It works fine with the key fob, but not the key. Has anyone here had this problem? If so whats the fix?
Thanks,
Old Jan 10, 2014 | 08:26 AM
robby363's Avatar
Default Re: Central locking system doesnt work with key
Does the key turn or not turn?
Old Jan 10, 2014 | 08:37 AM
Originally Posted by robby363
Does the key turn or is the key lock frozen?
It turns, but only opens the driver's side.
Old Jan 10, 2014 | 09:45 AM
Well Pizza and I worked with some members on the other side of the pond. Apparently the Crossfire is configured differently to open the doors with the key. It only opens a the driver's door.
Old Jan 10, 2014 | 10:18 AM
It must be a security thing, to prevent someone getting in the car from a hidden position when you have just got into it.
The EU has many rules and this is probably one of them, a good rule to my mind.
The fob can be programmed to do the same thing over here.
Old Jan 10, 2014 | 10:25 AM
That's my take, and what I explained to our friend in Spain. He doesn't seem to happy about though....
Old Jan 10, 2014 | 06:16 PM
davidricca's Avatar
Default
Hola amigos, e leido el libro de crossfire y pone que cerrando con la llave tendria wue cerrar y abrir todas las puertas desde la puerta del conductor. Asi que algo mal esta en mi coche.... por cierto muchas gracias a todos e!
Old Jan 10, 2014 | 06:19 PM
bluecoupe's Avatar
I have never used the key to lock/unlock doors, hope I never have to.
Old Jan 10, 2014 | 06:49 PM
davidricca's Avatar
Default
Yo tambien nunca quiero utilizar llave, pero cuando algun dia se rompa el mando, no podre cerrar el coche.
Old Apr 8, 2014 | 04:06 PM
Mrblue 2250's Avatar
I can only open the drivers door with the key the remote does not work at all anyone else?
Old Apr 8, 2014 | 05:01 PM
RED DOG's Avatar
Do your door locks work using the lock / unlock button on the dash? If not, it sounds like your central locking module may have gotten wet. It is located in the right rear of the car. Look in the area where your jack & tools are stored. The central locking module is under that styfoam panel on the right side of the car. Check that area for water intrusion . . .
Do you have an SRT6? Coupe or Roadster?
Old Apr 8, 2014 | 05:31 PM
The simplest answer would be that the batteries in the fob need replacing, but you must have thought of that already. Right?
KDW4Him
18
Sep 1, 2021 05:47 PM
Hoppy
Dec 7, 2018 07:36 AM
gtjl
17
Jul 22, 2015 06:28 PM
66L72M21
Jul 15, 2015 04:23 PM
Fildo Dog
Jul 6, 2015 05:20 PM
