If RCM goes bad away from home.
Old Feb 10, 2014 | 06:48 PM
JEFASOLD's Avatar
Default If RCM goes bad away from home.
There is lots of info about resoldering the RCM if it goes bad but what do you do if you're away from home? Well, I found a tool that will find it's way into my small emergency tool kit, i's called a Cold Heat soldering tool. I have been using it on my model train layout and realized it would be ideal to redo the RCM. Available from Radio Shack it uses a 4 AA batteries, heats very quickly and is cool to the touch immediately after soldering. No wires, no waiting for it to cool and it is small to carry
Old Feb 10, 2014 | 07:30 PM
bluecoupe's Avatar
Default Re: If RCM goes bad away from home.
.......or you could use this:
http://www.ebay.com/itm/NO-SOLDERING-GLUE-IRON-CONDUCTIVE-PAINT-INK-SHIELD-MINI-Z-XMOD-Rubber-Keypad-Fix/331126960746?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222006%26algo%3DSIC.FITP%26ao%3D1%26asc%3D20140107083349%26meid%3D4748359346871320905%26pid%3D100011%26prg%3D20140107083349%26rk%3D0%26rkt%3D10%26sd%3D331126257412
Old Feb 10, 2014 | 07:45 PM
6000rpm's Avatar
Both are excellent ideas! I was glad I was able to re-solder mine at home. What luck!
Old Feb 11, 2014 | 07:03 AM
Or you could do what I did : carry a spare one in the emergency kit along with the 2 Bosch CP sensors, the tire repair kit, the 12v jump starter and necessary tools. ( the spare serpentine belt is stored by the underhood accessory fuse box )
Old Feb 11, 2014 | 07:07 AM
What he said.....
Old Feb 11, 2014 | 09:48 AM
By CP I guess you mean one each of the Crankshaft and Cam shaft position sensors.
Also AAA or CAA cards and most importantly - don't leave home without it - a credit card with a high (usable) limit on it
Old Feb 11, 2014 | 09:53 AM
YES, sorry it wasn't clear
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
