Top Hydraulic Fluid leak
Old Apr 2, 2014 | 09:43 PM
cuziamninja's Avatar
Default Top Hydraulic Fluid leak
[Post Deleted]
Old Apr 7, 2014 | 08:07 PM
TopHydraulics's Avatar
Sponsor
Default Re: Top Hydraulic Fluid leak
cuziamninja,
welcome to the forum! You are having a leak on the bottom of the right main lift cylinder p/n 5170015AA. Your Crossfire has seven hydraulic cylinders, and they will all leak with time. They typically leak first on the bottom, and those leaks only get bigger. You must take care of it. Unfortunately, the cylinders were designed with seals that limit the life span to some ten years. The good news is, you can have the cylinder(s) rebuilt for a fraction of what the cylinder cost new when they were still available. Top Hydraulics upgrades all seven seals inside the cylinder, and makes it better than a brand new one that way. You may want to browse through the following, awesome thread by g3air with loads of photos and details: https://www.crossfireforum.org/forum...p-problem.html
Klaus
Rebuild/Upgrade Service for Chrysler Crossfire Roadster Hydraulic Cylinders - Top Hydraulics, Inc
Top Hydraulics | Rebuilt and Upgraded Convertible Top Cylinders, Pumps, Hydraulic Lines - Top Hydraulics, Inc
Old Apr 7, 2014 | 10:32 PM
awdspyder98's Avatar
Had the same issue with mine a few months back....Tophydraulics took care of it. Great customer service!
Old Apr 8, 2014 | 10:03 AM
Sponsor
awdspyder98,
I remember your case for a peculiar reason: you are one of the very few Crossfire customers for whom the other side didn't leak soon after we rebuilt the first one. Although all seven cylinders in the Crossfire convertible top system are bound to fail at roughly the same time (compared to their age), the cylinders which are used in pairs normally fail within weeks of each other. The reason is, the seals in these cylinders are from the same batch, they have the same dimensions, and they have been exposed to the same use and temperature fluctuations. Well, maybe the same side of your car was always parked in the shade, or the previous owner had just replaced the other cylinder before they sold you the car last year... ;-)
Hydraulic pump 5142638AA
Right main lift cylinder 5170015AA
Left main lift cylinder 5142639AA
Right bow tension cylinder 5170014AA
Left bow tension cylinder 5142640AA
Tonneau cover lift cylinder 5142641AA
Rear bow latch cylinder 05142957AA
Tonneau cover (storage cover) latch cylinder 05166559AA
Klaus
Old Apr 8, 2014 | 02:22 PM
Default
Originally Posted by TopHydraulics
awdspyder98,
Klaus
Yep... that's me. I was so waiting for the failure. . Checking it about every other day. So far so good.
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
