Wiring question.
Old May 13, 2014 | 02:22 PM
xme's Avatar
xme
Default Wiring question.
I'm sure I've seen this somewhere before but my search skills are failing me. Is there a trick to fishing a wire from behind the head unit down to the amp location, or do I have to remove the glove box and surround?
Old May 13, 2014 | 03:09 PM
Ottawa John's Avatar
Default Re: Wiring question.
I've only seen it done once - but remove the glove box. And disconnect the battery to save the air bag from possibly going off, too.
Old May 13, 2014 | 04:04 PM
xme's Avatar
xme
Well, may as well make a day out of it then, and get my USB and aux inputs wired up in the glove box, thanks!
Old May 13, 2014 | 04:10 PM
I did it without any problem, I pulled back the carpet and threaded a stiff piece of wire up behind the plastic trim and pulled a string back through and then the wire attached to the string, easy peasy.
Old May 13, 2014 | 04:44 PM
xme's Avatar
xme
I started poking around with a coat hanger last time I was in there, but it was cold and I wasn't having any luck so I decided to wait til spring. Hopefully I'll have better luck this time!
Old May 13, 2014 | 04:46 PM
Speedy4x4's Avatar
Default
On the hard plastic console tape the wire on the end of a pen then pish it from the bottom of the hard plastic console directly beneath the back of the radio with the wire taped on a pen you should reach it OK then you can use the one pishing it up along the bottom edge of the console forward up to the fire wall then you can run the wire under the carpet from there. Keep it hidden and you do not have to remove the glove box. That is the route I ran my mic for my head unit last week. I posted my route in my thread last week for my Kenwood marine radio. Looks like it was made for the car.
Old May 14, 2014 | 04:06 PM
xme's Avatar
xme
Ended up slipping an old hacksaw blade back there haha. Worked perfectly. Thanks guys!
Charlesl
Sep 30, 2015 10:46 PM
Sep 28, 2015 07:40 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
bobbie
Sep 12, 2015 12:49 PM
RiderJC
Sep 7, 2015 11:19 PM
