Misfire codes only when wet
Old May 18, 2014 | 12:17 PM
wraith13's Avatar
Default Misfire codes only when wet
Car sputters and throws codes. I've looked all over the forum and the web...I only get the cylinder misfire codes when I wash the car, go thru a carwash or drive in the rain. Tried spraying a mist of water on the engine in the dark looking for a spark...no luck...its random cylinders...will sometime go away on restart. But once it dries the car is fine.
The car runs great other that this issue.
Old May 18, 2014 | 02:41 PM
Default Re: Misfire codes only when wet
I'd recommend some new plug wires along with dilectric grease on both the spark plug ends and the coil ends.
Spray some electronic cleaner in all the coil connectors and let it dry before connecting the plug wires.
Time for some Magnecors ?
Hint : the very easiest way to change coil wires is to remove the valve covers. Seems stupid, yes, but you will be amazed how easy it is to get to the plugs and wires with them removed. You can unplug all the coil end wires and leave the coils on the valve covers.
Old May 1, 2022 | 11:04 PM
CaughtInaXF's Avatar
Had this one time, codes 300 and 30X's popping up after steam cleaning engine... was water in plug boot/s.
Figured it out after trying trouble shooting the coils, swapping in a new one I had, electric contact cleaner on connections, etc.
The plug boots had dielectric grease in them but still got wet enough to cause misfire.
I now blow dry motor after washing getting around plug boots and coil pack connections with compressed air.
Helps to use good quality plug wires!
... and if I recall it was both boots on cylinder 1 had moisture fwiw.
(pulled them off blew out with air and regreased to the max and made sure they were seated in all the way,,, maybe not clicked fully on the plug and boot wasn't maxed out so they got moisture in? IDK)
Then no codes, no stumble, ran great.
Cheapest fix there is....AIR
droopaloop
May 8, 2020 02:21 PM
d2_mcgill
30
Sep 15, 2018 12:35 PM
akakaz2
Mar 16, 2015 03:39 PM
pizzaguy
Jun 30, 2014 10:58 AM
SRT6_Roadster
May 1, 2011 09:00 PM
