Exhaust recommendations
Old Aug 17, 2014 | 05:10 PM
emforce's Avatar
Default Exhaust recommendations
OK, I was wondering what the best performance exhaust might be. Would like some sound when I "step on it" - but no drone at all when cruising. Any recommendations??
Emforce
Old Aug 17, 2014 | 05:15 PM
lildaddym's Avatar
Default Re: Exhaust recommendations
Too bad we can't use equal-length tubes to get some more power AND sound...
Old Aug 17, 2014 | 06:37 PM
Indelibility's Avatar
Good luck, seems like they all drone. Your best bet is the rear cat delete and debaffled intake elbow.
Old Aug 17, 2014 | 07:33 PM
velociabstract's Avatar
The biggest power gain is to remove all 4 cats but it's not what I'd do for a daily driver. Headers don't make significant power on our cars. My "why not" guess would be it has to do with the cam profile of our cars. From sound clips I've heard on youtube and here I prefer the Ansa and Megan for tone.
Les
Old Aug 17, 2014 | 07:36 PM
emforce's Avatar
I was thinking about Borla - as they seem to be almost as cheap as most..- but may just stick with what I have - seems to have a bit of a sound to it. (maybe just a hole in the exhaust system - LOL.) I am not a fan of a drone - got Magnaflow duals for my H2 - and sounds great most of the time - but trying to move something that big at 65 or 70 mph - just sets up a drone that drives me crazy.
Old Oct 16, 2014 | 12:40 AM
Sweet2002's Avatar
The Borla Pro XS Turbo muffler does not drone, nor is it quiet. For me I'll give up a few ponies for a Mercedes sound, smooth and quiet. I wil
Do the rear cat hammer and chisel job and then look at the muffler,as I have not yet seem,what it really looks like. There are dual in and dual out mufflers available, as for the resonator, it stays. It is simply a affluent chamber to eliminate some of the nasty sounds.
Old Oct 16, 2014 | 06:57 AM
The OBX catback still seems to be available from this vendor for $279 :
OBX Cat-Back Exhaust 2004-2006 Chrysler Crossfire 3.2L 04-06
I have had one installed for a year and a half now, just a bit of drone in the 60 - 75 range, but overall a smooth mellow sound.
( This a Chinese rip-off of the $800 Borla system, identical in every way including SS grade )
Old Oct 17, 2014 | 11:57 AM
johnnycross413's Avatar
I argee for a little under 300 go with obx, sounds real great easy to bolt up, comes with lifetime warranty. Win win
Old Oct 17, 2014 | 08:53 PM
JEFASOLD's Avatar
This has been the subject of several conversations and the consensus is that no one has gained more than a few HP. So go for the sound you want, and be happy. I am in the process of modifying my exhaust by deleting the back CATs putting in a Y pipe, then into a 3 in by 12 in resonator then 3 in into the muffler, bypassing the resonator. I think that the dual out system mods may actually flow too much, lowering the exhaust velocity, thus lowering the scavaging effect. By going from dual 2 1/4 to a single 3 inch may get the air velocity to a level that will aide in clearing the exhaust and maybe gaining a few HP.
Old Oct 17, 2014 | 09:33 PM
I'm trying to remember .... I'll get close. Removing the cats gets most of the gains, leave them and any changes are for sound quality and not performance. The difference on my car was 16 hp from removing the 4 cats. Open downpipes (Needswings) moved the total to 26 hp. Open headers was another 7 hp. Headers with stock resonator back was 4 hp. So the resonator and muffler only cost you 3 hp. These are peak numbers. Some changes lost some low end torque. If I had to do it over again I'd go another route with my disposable income. I may, in the future, remove the resonator and muffler and put something light weight, but not for power gains. For weight savings only.
Les
Old Oct 17, 2014 | 11:08 PM
syfi's Avatar
I've deleted the rear cats and "H" pipe and replaced them with an "X" pipe. Resonator remains in place and acts as the muffler since my muffler is also deleted. Resonator provides enough back pressure to be effective, yet allows more flow then the muffler. And NO DRONE, even without a muffler. Sound is very civilized until WOT, then she wails out the back, kinda like an uncorked Austin. The looks I get when I punch it next to some ricer who's revving away at the light is priceless.
You need an "X" pipe to eliminate the drone, and they are relatively cheap pricewise.
Here's the one I used... I went with the 2.25 in. SS model for under $40.
Results for X-Pipes
Old Oct 18, 2014 | 12:02 AM
JEFASOLD's Avatar
Results for X-Pipes
I plan to keep the muffler and delete the stock resonator and back CATs. I'm hoping that the single free flow resonator will keep it from droning. T had planned an X pipe but when I decided to go to the single 3 inch set up it didn't make sense so I am just using a dual 2 1/4 into 3 inch Y. Anybody know what the stock resonator weighs?
Old Oct 18, 2014 | 12:14 AM
syfi's Avatar
I saw someone mention that they thought it was around 15 lbs.
Old Oct 18, 2014 | 07:35 PM
JEFASOLD's Avatar
When I get mine out, I will weigh it, then we'll know.
Old Oct 20, 2014 | 11:14 AM
mobilefitt's Avatar
I'd go with this........
Daily driver
Universal JDM Weld on 2 5" Inlet Dual Square Tip Muffler Exhaust Chrome Canister | eBay
or this/ Race Application
Twin Cam Dual 3 5" Blue Slant Tip Axle Back Weld on Muffler Exhaust for Cirrus | eBay
have the local muffler shop chop it on the engine side of the resonator, hang it and fogeddaboudit.
Or pick your favorite muffler from here...
http://www.ebay.com/sch/Mufflers-/33...&_skc=50&rt=nc
There will be some drone, but it's not an unwelcome tone for someone that is looking to modify the already very sweet sounding exhaust.
Old Oct 20, 2014 | 11:21 AM
mobilefitt's Avatar
If your scared of that, I had to be talked into it and I saved hundreds and I'm happy....
Go with this!
It's cheap, its durable, and it's a copy of a much more pricey set up. Had this been available when I did mine, I would have had a hard time keeping the other $100 I saved by picking out a muffler with tips I liked.
Maximizer Cat Back Exhaust System Fit for 2004 2007 Chrysler Crossfire 3 2L V6 | eBay
Old Oct 20, 2014 | 12:17 PM
lildaddym's Avatar
Would it be productive to do true duals?
Old Oct 20, 2014 | 12:29 PM
mobilefitt's Avatar
on a limited.... nah.... maybe if you overboosting an SRT 6.
Old Nov 5, 2014 | 09:17 AM
Oconnom's Avatar
Hi,
I'm looking into removing my secondary cats but can't see them ! I've jacked the car up, can see the rear muffler and what look like 2 cats under the seat area. Are secondaries a US thing ? Mine is UK spec.
Mick
TerryR
Dec 13, 2019 03:27 PM
cuziamninja
Oct 5, 2015 10:39 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 28, 2015 07:40 PM
Big_Country
Sep 22, 2015 03:47 PM
