New Upgraded Mobil Jet Oil
Old Sep 28, 2014 | 10:01 PM
syfi's Avatar
Default New Upgraded Mobil Jet Oil
A new and much improved Supercharger oil...
Miami, FL September 26, 2014 - Leading aerospace fluids and parts distribution company, Sky Mart, has announced that it is the first to stock the long awaited Mobil Jet Oil 387. The next generation advanced aircraft-type gas turbine lubricant is formulated to provide the best performance characteristics of Standard Type 2 (Jet Oil II) and HTS (Jet Oil 254) oils. Sky Mart is also one of the first in its industry to distribute Mobil's long-awaited new turbine lubricant. Mobil Jet Oil 387 has been tested in laboratory and in high-stress land-based turbine applications under conditions that are even more demanding than normal aircraft service. It is also approved against the new SAE AS5780 High Performance Capability (HPC) standard. This civil specification was developed to meet the growing performance and quality needs that commercial airlines seek, especially with the entrance of new, higher-output and lower consumption engines. Mobil Jet Oil 387 has also been approved against MIL-PRF-23699-HTS.
Mobil Jet Oil 387 is commercialized for use in aircraft gas turbine engines, including turbo-jet, turbo-fan, turbo-prop, and turbo-shaft (helicopter), in commercial and military service. It is suitable for aircraft-type gas turbine engines in industrial and marine applications, and compatible with other synthetic gas turbine lubricants meeting U.S. Military Specification MIL-PRF-23699.
http://exxonmobil.com/aviation/Files..._factsheet.pdf
Old Sep 29, 2014 | 10:19 AM
meh03's Avatar
Default Re: New Upgraded Mobil Jet Oil
Figures, since I just bought replacement oil.
Old Sep 29, 2014 | 10:25 AM
Thornh's Avatar
Yeah - me too....
Big Daddy's Avatar
same here, just changed it 2 days ago...hate that smell!!
Old Sep 30, 2014 | 09:11 PM
SRT6_Roadster's Avatar
First question is did they really upgrade it? Or maybe a better question - is their idea of an upgrade the same as ours. Companies have called oils upgraded with the removal of zinc and other lubricating properties.
Second the stuff is cheap so changing the oil again is not an expensive endeavor. Although the effort would not be worth it until you are ready for the next change.
Old Sep 30, 2014 | 11:56 PM
syfi's Avatar
Maybe it just won't smell as bad?!!
Mobil Jet Oil 387 (Aviation)
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
PNA
Sep 5, 2015 02:20 PM
