Syfi's DIY DCAI
Old Nov 20, 2014 | 11:00 PM
syfi's Avatar
Default Syfi's DIY DCAI
I've had a few inquiries on how I made my DCAI, so I put together a pdf file that shows all parts used and where I procured them online.
Syfi's DIY DCAI.pdf
Old Nov 20, 2014 | 11:03 PM
tighed1's Avatar
Default Re: Syfi's DIY DCAI
Sweeeet!
Thanks for sharing!
Old Nov 21, 2014 | 12:26 AM
VA_NEWB's Avatar
Thank you so much.
Old Nov 21, 2014 | 07:46 AM
DTMenace's Avatar
Syfi
Great DIY job and pictorial!
Dennis
DTMenace
Old Nov 21, 2014 | 09:03 AM
blackpepper's Avatar
Where did you get those filters from they are nice
Old Nov 21, 2014 | 11:57 AM
syfi's Avatar
Read the pdf file I included in the post. Amazon was where I originally got mine. Link is in the pdf. You can search the P/N and maybe find it cheaper.
Old Nov 21, 2014 | 12:48 PM
mobilefitt's Avatar
Wow... that looks good!
Old Nov 21, 2014 | 01:40 PM
Larry Hitze's Avatar
Nice Job Syfi! Thanks
Old Nov 21, 2014 | 05:03 PM
you need a set of devil horns to finish off the look.... one of the nicest diy cai I have seen..... Max and Johnny have nice looking home made ones as well...
Old Nov 21, 2014 | 07:37 PM
Very nice! Thanks for sharing the details
Old Nov 22, 2014 | 01:54 AM
syfi's Avatar
Thanks Doc. I think I found some useable devil horns. I'll probably trim the flange and see how these will work. Should have them next week. If they end up being too flimsy, I'll try coating with epoxy or may even use them as molds and fab some custom FB ones. The size and shape looks like a good fit.
Allstar Performance ALL42141, Allstar Brake Ducts | Allstar Performance
UPDATE (12/1): Managed to fit the Brake Ducts. Trimmed the flanges completely off for easier fit. Just pushed them into the silicon hose for perfect grip without any need for clamps. One corner just does get behind the frame which holds them solidly in place. Drivers side was a PITA but it fit above the horn bracket without any modding.
Mike S
Old Nov 22, 2014 | 05:47 AM
now you're talkin'.....
Old Nov 22, 2014 | 01:48 PM
Those look like they will do nicely.
Old Nov 22, 2014 | 05:58 PM
maxcichon's Avatar
Wow...looks familiar.
Old Nov 22, 2014 | 06:59 PM
Does, doesn't it.....just as nice....
Old Nov 22, 2014 | 07:56 PM
syfi's Avatar
I'll admit that I used your idea for the inline filters. This is the SRT version. The straighter rammed-air flow into the filters just makes better sense to me. And the SL55 "Y" connector which simply clips onto the throttle body makes the install and removal of the entire setup super easy.
Old Nov 23, 2014 | 01:19 PM
boostmonkey's Avatar
Default
It has been done before with good success. Nice intake!
http://www.fabtech-performance.com/#...-intake-system
Old Nov 23, 2014 | 02:41 PM
syfi's Avatar
Mercedes Benz AMG Performance Parts AMG Performance Packages
I tried one of his $250 "Y" pipes. The fabrication was one of the worst I've ever seen. Very thin metal, the welds were not cleaned up and the inlet to the TB was warped/ovaled from bad welding. Got my money back and his excuse was that the part got past QC and was not the norm. He doesn't have a favorable rep on the MB forums either. Way over-priced for the quality. But yes, he has the right idea.
Old Nov 23, 2014 | 07:00 PM
Man, at that price level you might as well go Needswings.
Old Nov 24, 2014 | 01:30 PM
blasco403's Avatar
I have almost an identical DIY DCIA. I used the following "T" to connect to the TB.
Black Rubber Intake Tee 3" ID: Intake Hoses, IntakeTubing, and Intake Clamps - Intakehoses.com
I also have a set of devil horns from Needswings, just can't see them in the picture.
TTYL
Ron
