Syfi's DIY DCAI
I used one of these the first time I did my DIY DCIA:
http://www.sfxperformance.com/parts/SPT9479.htm
It needs to be cut down to fit and also needs a 1" high piece of 3" silicone to connect it to the TB.
I still have the modified Y pipe and a ready to fit 1" high blue 3" silicone piece if someone wants it - $15.00 plus shipping costs. I may still have two 45 degree blue 3" pieces as well to connect to the two 90 degree aluminum pieces that then connect to the inline air intakes. If I have them, I would include also.
TTYL
Ron
TTYL
Ron
And I just couldn't see paying NW nearly $200 for a couple of sawed off 90 deg. pipe couplers. The brake ducts are computer designed for optimum air flow and are a little larger to catch more air. And @ a 1/4 the price!
My thoughts are that the inline filter setups will flow much better because of the directed straight flow of air at the front opening, whereas the curved front filter of the NW seems to breakup that flow up front and not be as direct into the intake opening.
The Y pipe you did for me is 1000x better than this thing, it came painted and was not nearly $250. That thing is a turd LOL
only a flow bench will tell you if you beat out the needswings...... turbulence can be a hinder as well....so I like my Needswings for flow.....but yours looks better....
Here is the 3" y pipe I am working on. It is aluminum. I haven't had time to finish it though.
Attachment 33622
Attachment 33622
Dodge 02 08 RAM1500 3 7 4 7 Dual Twin Air Intake Kit Red Filter | eBay
I've got the Needswing elbow-maf housing.. for an N/A .. anyone got a source for a reasonable priced Y that gives hood clearance? Got the spectre Y and by the time you add to break over 90 degrees it looks like it's going to be too tall for hood clearance. I'm sure the rubber T would work.. but I'd rather have something that diverts the air to a down flow vrs the "collision" from a T
I am going to order the 5 inch filters and adapt the outlet back down to 3 inches and get my radiator support cut to a true 3 inches,I am just interested to see if any ramair effect can be had with this intake,or increase in boost.
Looks very cool, but since your ordering the SL55 Y pipe.... why not just go all the way....
I did not see any change in boost on my car with different intakes.
Here's where you can get the SL55 wye new...Part # 1130900129 Price $107.69
*UPDATE* (2/26/2021) Updated price and location to buy
https://www.mbdirectparts.com/oem-pa...tor-1130900129
syfi what grill is that you have? I have ordered a few different ones and even had one on my limited. I have never been happy with quality of any of them... I havent saw the one you have for sale anywhere.
SRT-6.com - Chrysler Crossfire SRT-6
Get 15% off here...
https://www.crossfireforum.org/forum...tml#post780801
Mike S
Here's some pics with the "Devil Horns" installed. Still need to do some trimming on the drivers side one to get a proper fit...
Just wondering have anyone dynoed the inline filters vs the filters out front,I think at a certain speed the inline filters are getting some type of ram air affect so they should in theory produce a little more power at speeds than the outboard filters.
