Exhaust Muffler size
Old Dec 4, 2014 | 12:19 PM
Oconnom's Avatar
Question Exhaust Muffler size
For only the second time since I've owned my Crossfire, I met another Crossfire owner in a supermarket car park. Got talking and he told me he had a stainless steel performance exhaust fitted. Sounded real nice, just the sound I'm after, deep tone and not too loud. He says it is a free flow sports exhaust with the mid range sound (in between out and out straight through race and stock quiet). He was very pleased with it for sound and performance and admitted any gains in HP would only be seen on a dyno.
I took a peak under the back and noticed the muffler box was a round item about 12" x 6", single inlet from the stock Y piece and single outlet to a short Y and 2 tips. He also had the secondary cats removed.
I thought the muffler looked way too small and a little lost in the space ! But obviously works well.
I mentioned my thoughts on the muffler size and he said if he had opted for the quiet version, the muffler would have been twice the size (oval) and was happy the muffler man knew what he was doing.
Are there any guidelines/specs on optimum muffler size ?
It was a very good price and I'm sorely tempted.
Mick
'06 Aero Blue Coupe
UberMapped
Old Dec 4, 2014 | 12:58 PM
Default
I prefer the magnaflow catback exhaust
Sounds absolutely perfect
Do a search here
there's lots to be read about this
Old Dec 4, 2014 | 02:15 PM
Oconnom's Avatar
Default Re: Exhaust Muffler size
I've looked at the MagnaFlow, problem is I must have the OEM tips fitted, want it to look standard. Quite expensive in the UK, circa £400.
The spec says 14" x 5" muffler , but the picture looks like it has 2 mufflers side. by side?
Mick
Old Dec 4, 2014 | 10:06 PM
Yes you will need a single muffler to modify using the OEM tips
I once had the Ansa muffler on mine with the OEM tips welded and it looked perfect and sounded much like the Magnaflow
I don't believe the Ansa is available anywhere anymore though
It was a Universal fit muffler with the Ansa part # UN0827
You might be able to locate one somewhere searching that part number
Here was my mod photos using the OEM tips on the Ansa muffler
click >>>
Ansa Muffler Tips - OEM Modification - Part # UN0827
Old Dec 6, 2014 | 03:37 PM
Beaner's Avatar
This is what I did...
Same magnaflow mufflers as in the cat back setup but with out tips
Some pipe, an "X", a little cursing and looks good when the car is on the ground and you are walking by
Law3dog
Aug 20, 2015 10:16 PM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
onehundred80
Aug 12, 2015 03:08 PM
crymar
Jul 17, 2015 08:46 AM
syfi
Jul 12, 2015 05:59 PM
