Standard automotive 4-pin relay... trigger with 2.5v?
Old Mar 20, 2015 | 09:54 PM
chrisificti0n's Avatar
Default Standard automotive 4-pin relay... trigger with 2.5v?
Hey guys - so I am really trying to get my push button start working the way I *want* it to. Everything is fine, but I need to be able to send 12v to the module whenever the clutch is engaged as the unit will not make any changes (turn off car) if the clutch signal is not detected.
I have a 2.5v steady voltage when the clutch is pressed in.
I need to feed 12v based on that. 2.5v will not power a standard automotive relay.
I tried a 611T solid state switch, however it functions differently - 2.5v does activate it, but it switches the 12v on and off each time you press the clutch -- not 12v on when you press and 12v off when you release.
Any ideas? Suggestions (other than solder my keyed ignition back in lol)
Old Mar 20, 2015 | 10:41 PM
Default Re: Standard automotive 4-pin relay.... trigger with 2.5v?
Do you think 2.5v is enough to close the contacts on a 5v PC board relay? Just an idea.
Old Mar 21, 2015 | 12:06 AM
Possibly. I found this on EBay and ordered. I'll post back if successful. Can control 5-200vdc from a 3-?vdc trigger. 2.5v might do it.
DC to DC Single Phase Solid State Relay SSR 25A 3 32V 5 200V Clear Cover | eBay
Old Mar 21, 2015 | 08:04 AM
I would be concerned about that specification of 50/60 HZ in the specs if this is REALLY a DC-DC relay.
Old Mar 21, 2015 | 10:48 PM
KDW4Him's Avatar
I didn't see anything lower in a quick search.... CRYDOM Module,Input DC,Output DC,Red,2A - Solid State Relays - 1DTT2|ODC5 - Grainger Industrial Supply
Old Mar 26, 2015 | 06:56 PM
Default Re: Standard automotive 4-pin relay... trigger with 2.5v?
Its been a while but maybe this'll trigger a thought (pun intended)... Use a latching relay from your trigger voltage, when you release the clutch the relay latches until the next input from the trigger voltage, it'll then 'deactivate' Or am I not understanding your needs??. Maybe? I hate forgetting basic electronics.....
Valk
Jul 12, 2021 09:49 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
RED DOG
Oct 5, 2015 07:59 PM
tritongreen
Sep 18, 2015 07:32 AM
Bill F
South Forum
Sep 11, 2015 02:29 PM
