Need clarification on checking fluid level of automatic transmission
Old Apr 20, 2015 | 06:12 PM
IBLUBYU's Avatar
Default Need clarification on checking fluid level of automatic transmission
When checking automatic transmission fluid level, with engine running and at proper temperature (assuming), should reading on the dipstick, be with transmission in PARK, NEUTRAL, or IN GEAR. Maybe it doesn't matter if that's the correct way, but I'd like to know the way it's supposed to be. Thanks in advance.....
Old Apr 20, 2015 | 10:35 PM
KDW4Him's Avatar
Default Re: Need clarification on checking fluid level of automatic transmission
From the manual.....
4. Actuate the parking brake. Start engine and let it run at idle speed in selector lever position “P”.
5. Shift through the transmission modes several times with the vehicle stationary and the engine idling
6. Warm up the transmission, wait at least 2 minutes and check the oil level with the engine running. Push the Special Tool 8863A (1) in up to the stop and pull out again, read off oil level, repeat if necessary.
7. Check the transmission oil temperature. NEED THE DRBIII SCAN TOOL TO KNOW THE EXACT TEMP
Note: The true transmission oil temperature can only be read by a scan tool in REVERSE or any forward gear position.
8. The transmission Special Tool 8863A has indicator marks every 10mm. Determine the height of the oil level on the dipstick and using the height, the transmission temperature, and the Transmission Fluid Graph, determine if the transmission oil level is correct.
9. Add or remove oil as necessary and recheck the oil level.
Old Apr 20, 2015 | 11:31 PM
Howard, Rule of Thumb is always check it in Park or Neutral. Park being preferred for safety reasons.
Old Apr 21, 2015 | 12:33 PM
IBLUBYU's Avatar
Thanks James and KDW4 for your responses.
xfClifford
Mar 3, 2021 04:52 PM
sittininthesun
Aug 24, 2015 10:47 AM
Crossfireconv08
Jul 30, 2015 12:11 PM
chturner
Jul 24, 2015 04:47 PM
skeet370
Jul 18, 2015 01:02 PM
