Backfire
Old Jun 8, 2015 | 01:43 PM
kiskasky1's Avatar
Default Backfire
I have a 2005 crossfire that is backfiring and not throwing any codes. Any suggestions on what's causing it. Thanks
Old Jun 8, 2015 | 03:36 PM
RL67037's Avatar
Default Re: Backfire
Bad gas?
Timing?
Fuel mixture?
Does it do it when idling - when accelerating - when decelerating - when doing all 3?
Has the car been modified in any way?
Tell us the story and give us some more information.
RL
Old Jun 8, 2015 | 04:19 PM
kiskasky1's Avatar
Does not backfire nor stall out when at idle. It has been doing it mostly when accelerating and holding speed.
Old Jun 8, 2015 | 06:51 PM
RL67037's Avatar
Are you hearing the backfiring or are you just feeling the "sputtering"?
Is it constant or is it random?
Did this just start recently or has it been an ongoing problem?
If it just started recently, did you get gas from a new place?
It may be moisture in your gas - maybe try adding a bottle of Heet (or some other moisture remover) and see if that helps?
Old Jun 9, 2015 | 09:47 PM
kiskasky1's Avatar
I am hearing the backfire. It is going on now for almost 2 weeks. It is getting progressively more and more frequent. I'm getting gas from the same place as I always do. Fuel filter Is going to be changed tomorrow. New spark plug wires and coil packs will be installed the following day as soon as they arive. Tha car is completely stock.
Old Jun 10, 2015 | 09:53 AM
syfi's Avatar
Having timing that is too late (retarded) can cause this same thing sometimes if your engine is running too rich. When the exhaust valve opens, the mixture isn't done burning so it ignites the unburned fuel in the exhaust system and causes a loud bang.
Try doing a throttle reset first.
1. Get in your car
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
Bottle of Seafoam in the gas tank wouldn't hurt either....
Old Jun 10, 2015 | 10:22 AM
kiskasky1's Avatar
Thanks Syfi. I tried it twice just to be sure and it's still backfiring.
Old Jun 16, 2015 | 05:33 PM
blackpepper's Avatar
First maken sure your CEL light is working also I would check alln12 wiresnto make sure they are seated.
Old Jun 17, 2015 | 06:35 PM
Sorry about the typing I was using my little cellphone keyboard at the time.
Old Jun 18, 2015 | 06:21 AM
kiskasky1's Avatar
CEL is working. Wires are triple checked and still have a backfire. Thanks
jimmyjet
Nov 1, 2011 09:01 PM
Crossfire725
Oct 19, 2011 09:40 PM
Hayabusa1300
Dec 13, 2010 06:03 PM
musicnsurf
Mar 7, 2008 03:37 PM
cross1
Sep 25, 2005 01:43 AM
