Rear Fog Lights
Old Feb 3, 2005 | 03:53 PM
aschrager's Avatar
Default Rear Fog Lights
I would like to know if the Europeian Crossfires have rear fog lights like the MB SLK 320. The light switch does have a position for rear fog lights. Pull it out two clicks.
Old Feb 3, 2005 | 05:56 PM
Steffen's Avatar
Default Re: Rear Fog Lights
Yes we have rear fog lights. On the headlight switch are two positions. First pull out position is for the front ones and second pull out is for the rear fog light. Also we have on the headlight switch level adjuster to adjust the headlight.
Old Feb 3, 2005 | 06:19 PM
former NXMX5's Avatar
i ordered a driver's side taillamp assembly from Germany with the rear fog lamp lens in it. ordered it from CTD. if you want one and dont want to go the OE route, go here: www.rallylights.com
headlight level adjust? wow. is that electric? where on the headlight switch is it located?
Old Feb 3, 2005 | 06:31 PM
Steffen's Avatar
Yes it is an electrical thing that adjusts your headlights. It is located on the right side on the headlight switch. You can choose option 0 for one passenger or option 1 for two passengers and backs in the trunk. The adjustment is for a better driving by night. If you sit in you car with a passengers and back in the trunk then the car is in the back deeper as in the front. Then the headlights will shine more in the Air but you want the light on the street and not in the air. Then you choose option 1 and the headlights go down and the light is on the street and not in the air. If you drive alone then you choose option 0 and the headlights goes up and you see more in front of the street. Hope that will help you.
Old Feb 3, 2005 | 06:33 PM
aschrager's Avatar
Thank you. We have the switch but no rear fog lamps. Will have to see if the wireing is in the American version. Could you get the lamp part number. Thanks again.
Can you adjust the level of the headlights or just from low to high beam.
Old Feb 3, 2005 | 06:38 PM
CyberGreg's Avatar
Hey Rob,
Do you have a picture of that rear light and is the wiring already in the back or did you have to cobble something together yourself?
Thanks
Old Feb 3, 2005 | 08:10 PM
AlvinByars's Avatar
Cool! ... I was wondering what that second detent in the light switch was for.
Old Feb 4, 2005 | 09:02 AM
ill take a picture as soon as this snow goes away >(
theres no wiring at all. its a different wiring harness and its a different headlamp switch than the euro-spec models. i had to create my own little setup. right now my switch is in the trunk; once spring comes i want to run a wire into the dash and get a real switch that i can use to turn it on and off without getting out of the car. maybe by then il figure out how to hack into the headlamp switch and run it off there.
Old Feb 4, 2005 | 09:37 AM
CyberGreg's Avatar
Very cool.... my wife's Saab had a rear fog and it too had a seperate switch. I'm thinking anytime you feel the need to turn on the front fogs why wouldn't you want the rear fog on? So I would just tie it into the front fog switch or actually the relay.
Now... there is normally only ONE rear (driver-side) fog but depending on wether the car is RHD or LHD it could be in either rear light. In most Saab's everything was there except the bulb so you could easily make the rear fog into fog lights. Is the Crossfire that way too?
Old Feb 4, 2005 | 12:44 PM
i think two rear fog lights is misleading because it looks like brake lights. that being said... most, if not all British cars have two rear fog lamps, and newer German cars (eg. audi a6) and even one American car (Oldsmobile) has two rear fog lamps.
the general rule is whichever side of your car is closer to the center median, thats the side that the rear fog lamp should be on.
UK Crossfires have the rear fog lamp on the right side; German, Aussie, and probably others have theirs on the left-hand side of the car.
Old Feb 4, 2005 | 02:42 PM
Steffen's Avatar
Most cars here in Germany have only one rear fog lights. It is ever the driver side! You can switch the rear fog light on only if you switch on the front ones first then in second the raer ones goes on. It is a two way function. If you want you can use the wiring and hardware of the switch from the SLK. The system is very very simple.
Old Mar 18, 2005 | 06:11 PM
finally got around to taking pictures. not the best shot; its a bad time of day
[ PIC REMOVED. NEW PIC BELOW ]
Old Mar 18, 2005 | 09:15 PM
MI Roadster's Avatar
looks like the snow is gone here.
I can't tell where the fog lamp is.
Old Mar 19, 2005 | 06:27 PM
better picture. dont mind the license plate. theyre from the Miata --
Old Mar 19, 2005 | 07:07 PM
NJspeed69's Avatar
What are we looking for here? I don't see it.
Old Mar 19, 2005 | 07:51 PM
there is a rear fog lamp in the left taillight assembly. These are standrard on Euorpean/UK/Aussie Crossfires. (compare the two reverse lights)
Old Mar 20, 2005 | 11:55 AM
That's different! I guess I would think that it would be mounted lower somewhere. Thanks for the new pic.
Old Mar 22, 2005 | 07:52 PM
i just installed a Hella on convertiblenut's car; beneath the bumper, to the left of the exhaust. ill see if i can get a picture of that one too.
Hoppy
Dec 7, 2018 07:36 AM
Adrian_X
Nov 9, 2017 08:49 AM
axnguyen
Jul 21, 2015 11:41 AM
mike28117
Jul 17, 2015 01:59 PM
KwehCat
Jul 16, 2015 04:48 PM
