I found out why my subwoofers don't work. Totally shot speaker surround
Old Sep 13, 2015 | 03:57 PM
pioneer4x4's Avatar
Default I found out why my subwoofers don't work. Totally shot speaker surround
I wanted to take a look and see if the rear sub issue was wiring/amp/or the speaker itself. Yep, easy to see what the problem is. I am planning on ordering a surround kit and try to repair them.
Old Sep 13, 2015 | 05:21 PM
Reliableron's Avatar
Default Re: I found out why my subwoofers don't work. Totally shot speaker surround
Looks like mine sounds - guess it's time to try and get it out!
Old Sep 13, 2015 | 10:59 PM
pioneer4x4's Avatar
yeah, it was more of a pain than I expected. FYI, the top trim piece is held with T8 screws, and the speaker is 3x10mm nuts. It was kind of weird, after removing it, being able to tap on the gas tank.
Old Sep 13, 2015 | 11:19 PM
Thanks, guess you don't want to use the wrong length screws...
Old Sep 13, 2015 | 11:33 PM
pioneer4x4's Avatar
Sorry, let me clarify. CORRECTION The screws that hold top top trim on the carpet by the door use a T6 Torx bit. They are not on the speaker itself.
Old Sep 20, 2015 | 11:08 PM
pioneer4x4's Avatar
I repaired them both yesterday with the kit from eBay. $23 for 2 foam surrounds and tube of glue. It took maybe ½ hour each to remove the foam remnants and clean up the speaker. I used alcohol wipes after scraping off all the gooey foam, and tried to ensure I had the cones centered with no rubbing of the voice coil when I did the final mounting of the surround. They sound great and I am glad I decided to tear into them.
Old Sep 21, 2015 | 08:00 PM
mobilefitt's Avatar
With a little bit of grinding, you can get these to sit right into the stock sub box.
I have removed the rear portion of the box to minimize buzzing sound from plastic on plastic contact.
http://www.ebay.com/itm/like/310985570545?ul_noapp=true&chn=ps&lpid=82
Old Sep 29, 2015 | 04:22 PM
pioneer4x4's Avatar
Just as an update, I did eBay feedback for the repair kit, and they emailed thanking me.
I asked a few questions and this is the response from "Simply Speakers"
Thanks for the photo. We have seen our fair share of these drivers too over the years. You are correct the driver is more or less a proprietary one that you will have to pay dearly for at the dealership. If you go aftermarket you will also need to change the integrated amplifier. It’s a nice speaker for a stock factory system just an expensive one to replace. The newer foams are a better formula and more durable than the older foam. This give the speaker an expected life of 10-15 years. For an already 10+ year old vehicle this may be a 1 time only repair for many of us.
The eBay pricing is as aggressive as we can get. That is on ongoing 10% off our normal retail price. You can let anyone from the forum know they can order over the phone and we’ll be glad to honor the eBay sale price if they mention your post. Enjoy you’re the sounds in your Crossfire!"
Old Oct 31, 2015 | 08:35 AM
zip439's Avatar
I too have refoamed my OEM subwoofers after reading Pioneer4x4 post, not too difficult. It made a huge difference in the stock sound system. When I took the speakers out the original foam looked OK, but close examination revealed a crack all the way around the speaker between the frame and cone. I bought directly from Simplyspeakers.com. Their standard kit FSK-6P206 is an exact replacement for our subwoofer speakers $24.95. I also used their foam sealer, but warn that you can distort the new foam if you screw the gasket directly through the new foam as they show on their video site. I recommend you use an ice pick or similar tool to force a hole through the foam [I]AND[I] lightly lubricate the screw for the gasket with oil before attempting to tighten the gasket in place on the new foam. This is especially important if you use their foam sealer.
Old Oct 31, 2015 | 12:06 PM
syfi's Avatar
These may work out better than the foam...
6.5" Butyl Rubber Speaker Surround Repair Kit
2 6 5" Butyl Rubber Speaker Surround Repair Kit Woofer SB601 | eBay
Old Nov 5, 2015 | 01:28 PM
Flamenco2005's Avatar
Do you have the kit number and weblink? I am needing to do the same 1 rear and also 1 door speaker.
Thanks. Would have liked to see a video of the repair.
Old Nov 5, 2015 | 01:59 PM
pioneer4x4's Avatar
Chrysler Crossfire Subwoofer Speaker Repair Kit Infinity A193 820 04 02 Pair | eBay
Old Mar 18, 2021 | 02:17 PM
westlake23's Avatar
how did you know cone is cented. Did you input a audio signal ?
Kodebuster
Nov 5, 2020 04:06 PM
Hoppy
Dec 7, 2018 07:36 AM
Roty135
17
Oct 11, 2018 10:11 AM
Bifftws
Racing
Jul 28, 2015 05:31 PM
tom2112
Jul 28, 2015 08:12 AM
