noise in or under ECU
Old Feb 10, 2005 | 05:31 PM
Bob G's Avatar
Default noise in or under ECU
When it is really cold latley, I have a noise like a little fan spinning at high rpm. Starts when I turn on the ignition, even before the car starts and goes away about 3 minute later. I took off the cover for the ECU and it sounded like it was right in there. Dealer couldn't hear it as it wasn't doing it when I stopped in. They though it might be a fan in the ECU but I don't think that there is one in the ECU. It's no big deal but I just wondered if anyone else has or had it. The regular heating fan still works fine so it isn't envoled.
Old Feb 10, 2005 | 09:31 PM
TSaxMan113's Avatar
Default Re: noise in or under ECU
The only thing similar I experienced was the blower motor for the HVAC. A couple blades somehow broke off and were rattling around inside the housing. The rattling has stopped, so I haven't bothered to get it fixed.
Old Feb 11, 2005 | 02:26 AM
saskins's Avatar
I have had a similar humming sound myself. It too is really noticeable when I first start the engine. It does seem to go away after a couple of minutes. It seems like when the engine get to its warmed up temp, the sound fades away. I don't know my friends, Its a mystery. Has anyone noticed anything funcky with the electrical system?
Old Feb 11, 2005 | 02:53 PM
Infinity's Avatar
Could it be the air pump for the polution control system? It does function more frequently during the cold weather.
Old Feb 11, 2005 | 03:05 PM
AlvinByars's Avatar
I've noticed a similar sound since day one ... almost like a subdued high pitched whistle/whine. I only hear it on a cold engine start and it quits shortly after the idle drops to its normal level. Infinity's answer sounds very plausible to me.
Old Feb 12, 2005 | 05:48 AM
saskins's Avatar
Well I don't think its the smog pump. I'll get under the car tomorrow and take a closer look.
Old Feb 12, 2005 | 03:01 PM
Bob G's Avatar
The noise is just like a high speed fan but you do not have to start the engine to hear it. Just turn on the key and there it is. I know that it is either in the ECU box or something right under it and actually touching it as the sound is right there. I noticed that there is a control module box cooling fan and I'll bet that it is the culprit. I have to leave it at the dealership overnight so that they can hear it for themselves.
Old Feb 12, 2005 | 03:26 PM
Bob G's Avatar
Just noticed that the Control Module Cooling fan is located inside the front lower section of the Control Module box. It is wired to the Body Control Module and is switched on when the ignition is turned on. AH HA!!! It is attached via a duct from the passenger compartment to draw air to cool the Powetrain Control Module box. I'm willing to bet that the sound is, that fan.
Old Feb 13, 2005 | 12:20 AM
Bob G's Avatar
Confirmed that it is the CM cooling fan. I turned on the ignition and opened up the ECM box and right at the front you can see the 1 1/2 inch fan exhaust and it was blowing air. I wiggled the outlet and the sound changed. That's it! Now to get DC to hear it.
Old Feb 21, 2005 | 06:26 PM
Charlie's Avatar
I think that is the same noise that you can find in the MB ML suv under the dash
Old Feb 26, 2005 | 10:45 PM
BullFrog's Avatar
its a unique feature to the MB 3.2 liter V6. This is a rapid heating of Catalytic Converter feature and it makes that humming hi rpm fan sound only on cold start ups to warm the cats quickly.
Old Feb 27, 2005 | 12:54 AM
Bob G's Avatar
Bullfrog:
Haven't heard anything from the Cats yet but the noise I experienced is the cooling fan at the front of the control module box. It's happening more often and DC has one on order.
Old Feb 27, 2005 | 01:29 AM
BullFrog's Avatar
You misunderstood, the noise I'm talking about is the same one you're talking about coming from the front area like a fan real quick, this to my understanding is a feature of this engine and somehow that sound is something that is causing the cat's to warm up in under 1 minute due to the technology in this engine. I have attached a link of this information for your review. http://www.whnet.com/4x4/new_V6.html
Old Feb 27, 2005 | 03:34 AM
Bob G's Avatar
Bullfrog: Nice engine pic! I understood what you meant but I found the noise in the fan for cooling the ECU. It is at the front of the ECU black box and when it is making the noise I can actually grab the active fan and the noise changes, so it is just the fan itself. Thanks for the input. I'll let you know for sure when DC does the job.
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
RacerXofFL
Sep 15, 2015 05:00 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
