74mm throttle body upgrade
Old Oct 19, 2015 | 12:48 PM
Brady517's Avatar
Default 74mm throttle body upgrade
Alright so I have an 04 Crossfire.. automatic.. and I'm looking at upgrading the throttle body to a 74mm. Now, having said thst, I know nothing about what I need. Is there a certain kind, brand, etc? I'm assuming I can't just go buy a 74mm tb and slap it on there? Help me out.
Old Oct 19, 2015 | 01:00 PM
Speedy4x4's Avatar
Default
Good thread started with a walk through type in
N/a 74mm throttle body upgrade guide.
The part number for the right throttle body is there, I got mine from eBay off a donor car with 33k miles for $45 shipped.
Old Oct 19, 2015 | 01:30 PM
Brady517's Avatar
Default Re: 74mm throttle body upgrade
So as long as the part number matches, it should work?
Old Oct 19, 2015 | 02:54 PM
Travish's Avatar
Yes it should work, you need this also but swap the original sensor into the new maf "tube" Don't forget the new O-ring.
https://www.crossfireforum.org/forum...ade-guide.html
http://www.ebay.com/itm/AIR-FLOW-SENSOR-MERCEDES-BEN-VEHICLES-VARIOUS-BRAND-NEW-/160578454125?_trksid=p2054897.l4275&rmvSB=true
Old Oct 19, 2015 | 02:56 PM
Yes, but realize that the OEM plastic IAT/MAF piece will be a restriction unless replaced with one off a model with the 74mm.
You will reuse the old sensor if the new plastic piece comes with one.
Also very important to order a couple of new O rings for the TB before starting.
The ideal scenario is : 74mm TB, NeedsWings CAI ( either single or dual ) and a Eurocharge tune.
cjw
Oct 26, 2015 10:26 PM
Brady517
Oct 20, 2015 12:15 PM
Tahoe
Oct 2, 2015 11:34 PM
cjw
Sep 27, 2015 10:22 AM
Helot
Aug 15, 2015 04:19 PM
