Convertible top troubleshooting
Old Dec 30, 2015 | 04:01 PM
ant_man252's Avatar
Default Convertible top troubleshooting
I am New to CF.org recently purchased an '05 Xfire roadster with a non-functional top . I figured this would be a good project. After doing research I have learned that I am missing a part that goes in the trunk . I am looking for insight on steps to take to restore its functionality or if an existing thread is out there point me in the right direction .
I twist the release , the windows roll down, and nothing happens beyond that point. Also the light on the release button is always flashing.
Old Dec 30, 2015 | 04:43 PM
Travish's Avatar
Default Re: Convertible top troubleshooting
You will need to give more info about what is missing in the trunk. Where in NC are you? I am in Greensboro and could possibly help.
Old Dec 30, 2015 | 04:45 PM
ant_man252's Avatar
Im in charlotte, and from reading the manual it stated a piece must be in the vertical position , ill have to go back and double check the specifics.
Old Dec 30, 2015 | 04:48 PM
Yes, the divider must be up. The arm on the left end of the divider will then press on and close the switch, allowing the top system to run.
You are not far from our Spring Event - you might want to consider attending - it is a tremendous way to learn about the car you have.
Not only that, but you will meet a tremendous group of people:
https://www.crossfireforum.org/forum...-4-2016-a.html
Old Dec 30, 2015 | 04:50 PM
ant_man252's Avatar
Sounds like I need to start by looking into a divider.
Old Dec 30, 2015 | 04:57 PM
Why would someone take the divider out?
Old Dec 30, 2015 | 04:59 PM
ant_man252's Avatar
Your guess is as good as mine.
Travish's Avatar
The divider is not there? It's just the big carpet covered, folding piece that has the finger/hand hold in it. If the divider is missing, you could always put a rubber band around the switch to hold it closed and try the top again. The switch is over on the left side where the little arm of the divider clicks into place.
Old Dec 30, 2015 | 06:04 PM
ant_man252's Avatar
Thanks for the description I have the divider , and its up . Now Im able to unlock the D ring , get the top up but when i press the release button it does not do anything .
Mrmiata's Avatar
When I was "new" to roadsters.. the wife's car had the divider laid down and that switch has been hard wired or something.. (never have checked it out).. top worked fine.. didn't realize just how things worked till the top crushed an Armor All gift pack. That is when I realized that panel laying down was the "divider panel".. do you see the tank and sending unit-wires when you open the trunk? Or a carpeted piece laying back up in there?
Old Dec 30, 2015 | 06:05 PM
Mrmiata's Avatar
Well I guess that answers that.. LOL
Old Dec 30, 2015 | 06:40 PM
ant_man252's Avatar
There isnt any carpet in the truck just the wires.
Old Dec 30, 2015 | 07:15 PM
Mrmiata's Avatar
You mind find this thread useful...
https://www.crossfireforum.org/forum...sn-t-work.html
Old Dec 31, 2015 | 01:37 AM
Travish's Avatar
On mine I have to make sure the trunk is FULLY latched or it wont work. Stupid question but... you are pressing and then holding the top switch on the console right?
howard_dare
Aug 21, 2023 07:19 PM
dobermann
24
May 8, 2018 01:19 AM
MiamiTVR
16
Jan 20, 2016 05:57 PM
tolas007
Jan 1, 2016 09:20 AM
barber
Dec 12, 2015 12:37 PM
