2004 crossfire not starting
Old Feb 29, 2016 | 04:31 PM
ptrustfull's Avatar
Default 2004 crossfire not starting
I brought my crossfire for a alarm system.After a few days the mechanic gave me the bad news. He tried a lot and different mechanics but the car will not start. Even though the alarm is removed the engine will not turn over. I even can not read OBD codes, none, tried 3 different code reader and they all say "connection failure". I tried the violet starter wire behind the switch, it gives a solid 12v when turned but the violet wire that goes into the ECM just lights up a second. I do not hear any click of a relay. i soldered the wires in the relaybox no change, Where do i start finding the problem. Hope to find help here
Old Feb 29, 2016 | 05:14 PM
Steve Jr's Avatar
Default Re: 2004 crossfire not starting
Does the dash, light up? Do your headlights come on? Will doors lock an unlock? Have your mechanic, look up Skreem module on this forum under the Technical section! If your a DYIer, need more info., in order to help.
Old Feb 29, 2016 | 05:19 PM
ptrustfull's Avatar
The dash lights up, i notice 2 wrenches with -11100 behind it. I am a mechanic myself but the problem is that since i can not read codes and i don't know what happened i need a jump start. I bought a manual with all the wiring and tomorrow i will look at the pulse module. Didn't check the headlights yet and the doorlocks are not working. How can i see if the immobilizer has engaged?
Old Feb 29, 2016 | 06:36 PM
There are 3 general symptoms :
1. Dash lights light, starter does not engage. ( generally the RCM module )
2. Cranks over but does not start, 3 times , then nothing until you reset by disconnecting the battery : generally a SKREEM ( security module ) issue.
3. Tries to start, no 3 limit : generally the Crankshaft Position Sensor or harness contacts to it.
Old Feb 29, 2016 | 08:18 PM
Steve Jr's Avatar
The 2 wrenches and 11100 indicate, it's time for the B maintenance schedule to be attended too and how long it's been!
Old Mar 1, 2016 | 11:36 AM
ptrustfull's Avatar
Lights turn on. The lock/unlock button on the dash does not work. The tow switch light stays on all the time and the spoiler light keeps blinking when ignition is on. Spoiler does not move. With ignition on all usual dash lights turn on. I checked the violet wire going to the starter and both are good. Noticed that when i put a test light at the ground sensor wire (pink/red) the starter motor turned. I also mentioned that i am not able to read OBD codes "no communication with ECU". Also measured the ground sensor wire (brown/yellow) to the ECU and i am getting 0.00 volts with ignition on. Before i take the conclusion that the ECU is fried i will need to find all ignition and battery wires going into the ecu and see if they get juice. Allready measured all fuses twice and they look good. Maybe one not important thing. As sson as i switch the car on the fan starts running at top speed. I purchased the manual so i can trace all wires and stuff. Help is greatly appreciated
Old Mar 1, 2016 | 10:48 PM
KDW4Him's Avatar
Have you checked ALL fuses?
Did this alarm system also have push button start for the car?
Who did the alarm install? They might be able to help as to what they did on install.
Old Mar 2, 2016 | 12:18 AM
WindRestrictor's Avatar
Former Vendor
All of that makes a lot of sense.
Old Mar 2, 2016 | 12:59 PM
ptrustfull's Avatar
Got it to start. I measured the grounds and ignition power wires on the c5 connector. There was one red/green wire that was not getting power. It gets it power from the rcm. The middle relay (ECU power) was the problem. I think that it was burned in, it clicked but did not let the power through. replaced it and now it is running again. Thanks for all the help.
Old Mar 2, 2016 | 03:18 PM
autumnmass's Avatar
Glad to hear that your up and running!
Reichsrundfunk
19
Jan 30, 2018 12:34 AM
mymaterick
Mar 2, 2016 09:59 PM
soxih
Jan 19, 2016 06:02 AM
Toolman
Dec 2, 2015 11:08 PM
kusheen
Oct 13, 2003 04:25 PM
