Bad Vibration in Reverse/Idle
Old Mar 17, 2016 | 01:47 PM
cuziamninja's Avatar
Default Bad Vibration in Reverse/Idle
Everything about my car is running smooth but recently when i put it in reverse the car shakes badly. When I switch to drive it smooths out instantly. This also happens not as badly when im stopped holding break. Any touch of the gas makes it go away instantly.
Could it be engine mounts?
Old Mar 17, 2016 | 02:23 PM
Default Re: Bad Vibration in Reverse/Idle
Yes, it could be the engine mounts.
Old Mar 17, 2016 | 02:25 PM
JSK's Avatar
JSK
Sounds kinda like a vacuum leak.
Old Mar 30, 2016 | 12:41 PM
That's what i was thinking. Is there any way to test this or any cleaer signs?
It seems to be getting worse every day.
The second i touch the accelerator all the shaking/noise stops.
Old Apr 19, 2016 | 03:29 PM
Any other suggestions for this?
The problem is getting worse. Once it started shaking very badly and the AC fans cut off for a few seconds then came back.
Any ideas?
Old Apr 19, 2016 | 05:28 PM
kingdavid54's Avatar
Any ideas?
Go to one of the Mercedes-Benz forums and Snoop around someone there may have had the same experience, good luck hope you find out what it is , please check back and let us know . PS; check the transmission mount
goykgo
19
Jan 28, 2020 11:32 AM
cjfine
Feb 7, 2017 01:01 AM
kstewart
17
Mar 30, 2016 04:48 PM
cdcrone123
33
Mar 23, 2016 09:09 PM
cuziamninja
Mar 16, 2016 10:39 PM
