Misfire
Old Mar 21, 2016 | 11:10 PM
JEFASOLD's Avatar
Default Misfire
Friday, while cranking it up for the first time this Spring, near redline the car coughed and hesitated CEL light, followed by rough idle. The code was misfire cylinder 6. After cooling down and resetting codes, the car ran fine, that is, until I cranked it up again with the same result. I swapped the coil packs between cylinders 5 & 6, and this time had cylinder 5 misfire. This indicates a coil malfunction, so I ordered a replacement OEM Bosch unit from Rockauto, which should fix the problem. This is the first issue that I've had with the car, which I've had since 2012!
Old Mar 23, 2016 | 11:57 PM
Sweet2002's Avatar
Default Re: Misfire
Jim, hope you make out with then coil. Sometimes it's just one of those things that give out for no seen reason and you are cranking again! Mark
Old Apr 2, 2016 | 12:46 AM
JEFASOLD's Avatar
Default Re: Misfire
Just a follow up. New coil cured the problem, the car runs like a jewel again.
Old Apr 3, 2016 | 07:02 AM
Bird33's Avatar
Default Re: Misfire
Thanks for sharing and good job...
saysy
Mar 10, 2016 03:46 PM
KDW4Him
Mar 3, 2016 11:00 PM
Travish
Mar 3, 2016 08:36 AM
foxxfire7
Mar 3, 2016 08:07 AM
cuziamninja
Mar 2, 2016 03:38 PM
