Odometer etc stays on key off
Old Sep 7, 2016 | 08:18 PM
White Thunder's Avatar
Default Odometer etc stays on key off
Hi everyone lm a newbie to crossfires just trying to get a couple glitches figured out on my new to me ride (2004 coup).....my odometer ,clock,temp stays on even when my key is off ....how do l turn them off? l played around with the two ***** on cluster they went off .....then when l reset trip odometer they stayed on again. ....what am l doing wrong ....l dont have a owners manual. ... ideas anyone .
Old Sep 7, 2016 | 11:42 PM
Default Re: Odometer etc stays on key off
Ahhhhhhhhhhhh, they stay on for about 30 seconds.
They also revive when you:
  • Open a door
  • Turn the key to any position other than full off
  • Turn on parking/headlights
  • Open the trunk
I get the idea from your post that you expect the displays to go out right away - I've never timed it but I THINK the timeout is about 30 seconds. If they NEVER go out, I would think most likely that you have a bad door or liftgate/trunk switch.
Old Sep 7, 2016 | 11:44 PM
Oh, and there is a switch in the ignition that senses a key is present. I've never paid attention, but I THINK that if you do not remove the key, the display stays on as well. But I'm not SURE about that. My car is 450 miles from me so I can't go test that right now................
Old Sep 8, 2016 | 09:16 AM
Perhaps part of my problem is that my doom light also doesn't work......could it be that car thinks door is never opened. ...also my remote will not open doors ....this is how l got car .....you think all these issues are related??
Old Sep 8, 2016 | 11:13 AM
Yes, most likely related.
Have you checked all the fuses ?
Check the signals from the door switches.
( not easy, either at the seat relay or the CLPM ) :
Old Sep 8, 2016 | 01:20 PM
Dome light problem could be that the switch on the dome light is in the OFF position, it has two positions.
The door problem could be the pump in the trunk has got wet and has given up the ghost. It controls a lot of items and controls the dome light OFF. The lights going off when you stop the car etc. So it too might be the source of your dome light problem and the odometer trouble.
Also a leak in the air lines somewhere will stop the door locks from operating.
pcarsdoc1
Jul 24, 2016 04:05 PM
vitale
Jul 6, 2016 02:17 PM
chrono2nd.sr
Jun 23, 2016 09:17 AM
WindRestrictor
Jun 20, 2016 12:04 AM
CrossfireZona
Jun 13, 2016 10:59 AM
