Headlight
Old Oct 9, 2016 | 01:38 AM
Jacques Levesque's Avatar
Question Headlight
My headlights were out of alignment and I took them to a Chrysler dealership and they are now worse than before....both headlights seem to shoot way too far down.... i there an easier way to fix this myself?
Old Oct 9, 2016 | 01:44 AM
Mrmiata's Avatar
Default Re: Headlight
Most common cause for this is the tab on the bulb is not seated into position.. you will also notice a white knobbed adjuster on the back.. don't "force" it once there is resistance to turning or you may pop it off the socket inside.
Old Oct 9, 2016 | 01:49 AM
Mrmiata's Avatar
Tab shown at the bottom here (low beam)..
Old Oct 9, 2016 | 09:35 AM
You can align the bulbs yourself if you have a flat area in front of a wal or garage door. Make sure the bulbs are located properly in the sockets of you are wasting your time. Unless someone has played around with before you only need to adjust the headlight itself and it sets both the high and low beams.
You could get BigDaddy who lives in your area to help you, either way it is better than the stealerships as you have found.
cudaman
Jun 2, 2017 09:48 AM
champagnevelvet
Oct 6, 2016 07:33 AM
Grelims
Oct 5, 2016 11:19 AM
maniacsparadise
Sep 30, 2016 01:19 AM
Steve PD
Sep 24, 2016 09:34 AM
