ABS & BAS ESP lights are on
Old Apr 1, 2017 | 02:30 PM
unifil81's Avatar
Default ABS & BAS ESP lights are on
I cant find the combination of these lights in the manual.
Old Apr 1, 2017 | 03:08 PM
KDW4Him's Avatar
Default Re: ABS &BAS ESP lights are on
There should be a section in the owners manual how to reset the light if it was caused by the steering wheel position sensor out of cal.
Old Apr 1, 2017 | 07:12 PM
S8MS-01904's Avatar
I think the instructions are to turn the steering wheel full left then full right.
Old Apr 10, 2017 | 12:26 PM
sirharper's Avatar
Default Re: ABS & BAS ESP lights are on
If you're lucky it's only the steering calibration. I've had to replace the steering angle module and yaw sensor to cure that issue when I had it.
Old Apr 10, 2017 | 02:55 PM
tighed1's Avatar
If the wing comes up and stays up along with this fault, could be the traction control relay in the RCM.
Old Apr 10, 2017 | 03:06 PM
He posted this as his first post ever nine days ago and has not been back since.
It is not the fault of the steering wheel needing to be reset as the ABS is not set for that fault as far as I can recall.
He never gave much info and then disappeared back where he came from in Europe I guess.
ramiusxxx
33
Aug 29, 2020 05:01 PM
rfourt
Mar 1, 2017 09:36 PM
Desertcasino
Feb 24, 2017 10:32 PM
Alem12
Sep 7, 2016 08:20 PM
KDW4Him
21
May 13, 2016 09:47 PM
