oil pressure notification
Old Apr 20, 2017 | 03:12 PM
Johnny's Avatar
Default oil pressure notification
I keep getting an oil pressure "HI" notification every time I drive my Crossfire. It always seems to come on at the same location on my way home. What gives?
Old Apr 20, 2017 | 03:31 PM
Default Re: oil pressure notification
Probably in a pretty sharp corner, right ?
If so, oil level is probably too high, need to suck a bit out until it's not over the top dipstick mark.
Old Apr 20, 2017 | 04:10 PM
Or the sensor is reading a wrong level and needs to be replaced.
Old Apr 20, 2017 | 05:57 PM
It's not a pressure alarm, its a level alarm. My first two Roadsters did that on 8 1/2 quarts in tight curves of on downgrades.
My current car got an 8 quart change when I got it home - never seen the alarm.
So............
If you are putting 8 1/2 quarts in at oil changes, put in 8 next time.
If you are already putting in only 8, see post 3.
Old Apr 20, 2017 | 06:07 PM
JSK's Avatar
JSK
The oil light on my SRT has come on a couple times lately. Oil is right on full line on dip stick, I do oil changes from the top and put in eight quarts and I can't get an electronic readout. My guess is bad sensor. I need to buy a hoist. I'm too damn old too do that on the ground. My garage opens to the alley and the driveway is three lanes wide. I'm pretty sure I need a hoist.
Old Apr 20, 2017 | 06:10 PM
So............
Some peoples cars are friendlier than others and say Hi.
Mine is more conservative and says nothing except when I have the Nav radio in it and then it will just not shut up.
Old Apr 20, 2017 | 07:06 PM
markr6754's Avatar
I mistakingly added 10 1/2 quarts to my Crossfire during an oil change about 3 years ago. I never noticed on the dipstick, because I didn't check after adding the oil. I "knew" exactly how much I put in...so why bother (yeah, dumb move!).
The next morning I got the Hi Oil alert after about 15 minutes driving. It still bothers me that the alert wasn't presented immediately after starting the car after the oil change...but there you go. I was not in a place where I could do anything about it, so I drive for the day, and on my return I sucked "some" oil out. The alert went away, and I feel better.
Next morning...same thing. After 15 minutes driving, the Hi Oil alert returns. And once again, I can't do anything until the end of the day. This time I decide to keep sucking until I can see the right level on the dip stick. After a short while of sucking I said out loud...this is ridiculous...where is all this oil coming from? Then it hit me...the two - 1 gallon jugs of Mobil 1 that I used were, in fact, 5 quart jugs. And the 1/2 quart that I'd saved from my previous oil change was just additional insult. Terrible lesson...and with a lasting legacy. That's when my valve covers began leaking...with just enough drip on the exhaust to bring back memories of my old 1962 Ford Galaxie....the first car I ever bought. Whether conventional or synthetic, oil on exhaust manifolds smells the same.
Old Apr 20, 2017 | 07:44 PM
We have all had our 'moments'... Mine was adding all 5 quarts to my 1972 fury III (way back in 1974), and then checking the dipstick and seeing nothing on it. Seeing all 5 empties, a sick feeling came over me when I saw the oil pan drain bolt on the radiator crossmember. I just dumped 5 quarts of oil down into the dirty oil recovery tank at the plant I was operating. At least it was a cheap lesson. Getting a lift to the store to buy another 5 qts, was the hardest part.
Old Apr 20, 2017 | 08:21 PM
BAS International Blue Mohair top (Installed by ala_xfire)
Did you catch that George ? See I can do something useful other than just type on this forum
Old Apr 20, 2017 | 10:18 PM
I do miss my NAV head unit from the Graphite - I had it set to the english lady voice - made me feel like Bond.
James Bond.
Old Apr 21, 2017 | 01:20 AM
lovecross's Avatar
Wink Re: oil pressure notification
James Bond.
007 might be driving a "Range Rova Spot" or a "Jagua" now. (friend @ work could easily double for "Odd Job" if you can imagine that, LOL!)
Old Apr 21, 2017 | 06:26 AM
I get a bit of that from my Garmin, I have it set to the English lady voice.
