Fault Code Help
Old Jul 29, 2017 | 02:12 PM
cobray's Avatar
Default Fault Code Help
Got my Launch CRP123 odb2 and got the below codes. I did a search on the forums and did not see anything. And went through the list here .
I chose Benz, R170 16 Pin and C320 to do the test on. I have a 2008. Did I pick the wrong one to scan on? or am I just lucky to get codes no one else has?
My BAS\ESP and Airbag lights are on. The BAS\ESP can not be reset via wheel left/right.
P2404
P1018-000
Thanks in advance
Old Jul 29, 2017 | 02:35 PM
Default Re: Fault Code Help
Got mine too. Did you do the update ?
Not very intuitive, but I got it done.
I would agree that benx R170 C320 is probably correct, I haven't hooked mine to the Crossfire yet, but I did run it on the 2002 Concorde and it worked fine.
P2404 - possibly the charcoal cannister ( back with the pump and filter ) ?
P1018 - maybe the short runner / long runner flap inside the intake manifold ?
There is a little vacuum line that has caused problems on that for other folks.
Old Jul 29, 2017 | 02:58 PM
Steve Jr's Avatar
I guess your just lucky. I even went to totalcardignostics.com , those codes aren't listed. Try C320 and the R170 platform ,
on the Actron site , I find those codes , BUT its not where ala_Xfire is...lol.
Take a look at that site George, see what you think.
Old Jul 29, 2017 | 04:38 PM
I hooked my Crap 123 up to the XF after I updated it, there IS a selection for the SLK320, I chose that.
I ran all scans and diagnostics, nothing wrong on mine.
Readouts jive with my UltraGuage, and this thing even gives you oil temperature and battery voltage !
( no oil pressure though )
Old Jul 29, 2017 | 04:41 PM
https://www.autocodes.com/p1018.html
and
https://www.engine-codes.com/p2404.html
Old Jul 29, 2017 | 05:06 PM
Steve Jr's Avatar
You have to put in the correct information , to get the right answers.
Old Jul 29, 2017 | 05:23 PM
I'll be bringing the CRP123 to the Fall Dragon, free scans for all !!!
First come, first serve.
Old Jul 29, 2017 | 05:33 PM
Steve Jr's Avatar
​​​​​​Frist....
Old Jul 29, 2017 | 08:04 PM
cobray's Avatar
Updated the CRP (thanks ala xfire). Ran it again.
Codes and Readout
Transmission - P2404 The stop lamp switch signal sent from the traction system via the CAN bus is implausible.
ESP - 1018-000 The fault code is not found in the database.
Did some searching and found P2404 here. However, I don't know what that means or what to fix.
I can not find anything on the ESP fault code 1018-000. The traction light on the speedo does not come on and I can't not turn off BAS/ESP with the button.
The CRP won't read the Airbag DTC. It goes into the Hint screen and stalls, nothing happens.
Old Jul 30, 2017 | 10:31 AM
Steve Jr's Avatar
Well ...you have come up with the codes I did. Thought I was crazy (boss says I am). The other code is for the seatbelt tensioner or retractor. BUT , I got these codes off the aforementioned site , using an 04. C320 base model, ( not 4maic ). Remember ...put in wrong parameters , get wrong answers.
Old Aug 1, 2017 | 11:09 PM
cobray's Avatar
How is the seatbelt tensioner related to ESP?
The site shows the same description as the odb2. I don't understand why you keep saying put in wrong parameters get wrong answers, I have said from the start what I am putting in and they are correct. So far responses on this forum are completely unrelated to what the issue is.
Old Aug 2, 2017 | 12:36 AM
Steve Jr's Avatar
Wrong parameter means you're not using the SLK320 model. As far as the seat belt tensioner/ retractor , the code I found (P1018) on the Actron site said that's what its tied to. On our cars , It runs into the ORC which acts as readiness for the SRS an that lights the airbag light, which is on , on your dash..correct. Good luck...
FYI , neither one of those codes are listed in our service manuals. Ala_Xfire found an answer , I found an answer , hope you find an answer that works.
Old Aug 2, 2017 | 09:27 AM
If you up have ESP you have no need for a code reader, you'll just know.
Cue up the haunting music.
