Custom Tailight wiring.
Old Nov 7, 2017 | 02:45 PM
Rsoe's Avatar
Lightbulb Custom Tailight wiring.
Hi I'm new here. Anyway.
I have a 04 crossfire base.
I tinted my tail lights red.
As you know,
the outer bulb is the brake light
the middle is the blinker
and the inside bulb is the reverse
I wanted to make the middle blinker and reverse into a brake light.
but also wanted to make all bulbs flash.
(maybe a sequential timer for kicks)
i tinted the reverse too so figured i might wire the reverse separately to an external reverse bar.
so I guess I want all lights to blink but also turn on when braking.
Anyone have a tail light wiring schematic?
BTW : Thanks for the radio diagram to whoever posted it with the corresponding sides and polarities. Helped tons and now my crossfire bumps with the stock amp
Old Nov 8, 2017 | 07:09 AM
Default Re: Custom Tailight wiring.
You can access the service manuals that contain the wiring diagrams in the below link.
Old Nov 9, 2017 | 03:43 PM
Rsoe's Avatar
Thumbs up Re: Custom Tailight wiring.
I was able to pull it up at school using shop key pro.
So what I did was bridge the brake light + wire to the blinker + wire.
Its pin 3 to 4 on the harness connector.
Only thing now is my blinkers turn on when I brake as well the indicator on the cluster.
What I need to do is install a diode on the blinker wires so that current can't travel up to the pcm and indicator lights but only current going to the bulb.
Old Nov 9, 2017 | 04:04 PM
Rsoe's Avatar
Thanks for the link. will definitely help. I'm gonna do my instrument cluster ligjt s next
Old Nov 9, 2017 | 04:21 PM
Steve Jr's Avatar
Wouldn't a diode , cause the light out indicator on the dash , to constantly light, not being able to complete it's cycle check , for not working bulbs?
Old Nov 9, 2017 | 04:53 PM
KDW4Him's Avatar
Can you add dual filament sockets for the additional lights you need?
