'05 crossfire oil gauge
Old Dec 4, 2017 | 09:32 AM
wgc's Avatar
wgc
Default '05 crossfire oil gauge
Hi is there an oil pressure gauge on a 05 crossfire. can not find one??
Old Dec 4, 2017 | 09:41 AM
Default Re: 05 crossfire oil gauge
It is beside the spare tire.
No gage just a light bulb. You can add one though if you want to.
Old Dec 4, 2017 | 09:45 AM
Steve Jr's Avatar
No , not a gauge. There are Hi and low level displays that alert ,your attention.
Old Dec 4, 2017 | 10:50 AM
wgc's Avatar
wgc
Thanks Steve .
Old Dec 4, 2017 | 10:52 AM
wgc's Avatar
wgc
Thanks. Gary
Old Dec 4, 2017 | 12:18 PM
He asked about pressure and the only thing that would warn you is the CE light.
That would be my answer.
Old Dec 4, 2017 | 02:31 PM
Steve Jr's Avatar
Yes, I have found when I use the term, "idiot light", people take that personally.
Old Dec 4, 2017 | 06:52 PM
There is no oil pressure sensor on the M112 engine. Minimum spec at idle with a hot engine and 0W40 oil is 3 pounds. Kinda makes a sensor useless at that point.
There is a plug in the front of the engine below the oil filter where a mechanic (or YOU) can measure pressure - go read about it in the manual - 3 pounds at hot idle is all you expect to see. 5W50 gave me 9 pounds at hot idle, I've not measured 5W40 but I'd guess it's just over 5 pounds.
I had an oil pressure gauge on the Graphite, but have never got around to putting one on the SE.
Old Dec 4, 2017 | 08:04 PM
wgc's Avatar
wgc
That you very much that info will help
Old Mar 19, 2018 | 11:24 AM
LGV-XFIRE's Avatar
Default Re: '05 crossfire oil gauge
Just had this issue (freaked out when my check oil light came on, and put too much oil in) the oil pressure indicator is in the trip meter and will display "HI" on it if the pressure goes beyond normal.
Old Mar 19, 2018 | 12:18 PM
That is not an oil pressure indicator, it IS the oil LEVEL indicator. You'll have to drain some out before the level sensor gets jammed (some have reported the sensor jamming after too high a level).
Old Mar 19, 2018 | 02:13 PM
We can repeat ourselves all we want to, but people have "oil pressure" in their heads. And for good reason, every vehicle I've ever had, had an oil pressure sensor. Not the Crossfire, and I'd bet, not any MB with the M112 engine in it.
Old Mar 19, 2018 | 04:13 PM
Not only that, but they don't even bother to put it in the OBD data stream
Old Mar 19, 2018 | 05:31 PM
Speedy4x4's Avatar
Which doesn't make sense, something has to tell when to turn the light on.
torque has alot of displays, but a oil pressure gauge is not one of them.
I originally installed a electric oil pressure gauge, but changed to a manual with copper line.
I like a vacuum gauges, can tell alot about a engine condition with a good vacuum gauge, and is good to carry around when used car ahopping.
onehundred80
Apr 16, 2025 04:43 PM
Valk
Aug 4, 2016 08:13 AM
flyntgr
Aug 4, 2016 07:00 AM
TORONTO-X-FIRE
Jul 28, 2016 08:58 AM
TexasSRT
May 9, 2016 09:40 AM
