Is this Mystery No Start?
Old Dec 16, 2017 | 02:01 PM
Raindem's Avatar
Default Is this Mystery No Start?
So I'm cruising along at 50mph and suddenly the engine cuts out. No sputtering. Just dies (and yes it has gas). So I coast over to the shoulder and recycle the key. All electronics work but it won't start. Doesn't crank. Just silence. Try it a couple more times. No joy. After about 5 minutes of figuring out who I'm going to call to come get me I try it again and it starts right up. I'm only a few miles from home so I take it back with no further problems.
I get home and pull codes. The only code is the P0410. I used to have this all the time but since I replaced the secondary air pump a few months back it's been fine.
The final clue is that I can't erase the codes (I used to be able to with this reader). It lets me go through the steps and says they are erased. But when it is done the same code is still there.
So I've been reading up on the Mystery No Start issue and plan on touching up the solder joints (or sending it to Tighed1). But I'm curious about not being able to erase the codes. Is that a common symptom or is there something else going on here?
Thanks
Curt
Old Dec 16, 2017 | 02:14 PM
Padgett's Avatar
Default Re: Is this Mystery No Start?
Are you trying to erase with the engine running or just the key on ?
This is why I bought an iCarsoft MBII (not i980) because Torque Pro and other generic readers just get the generic "P" codes and not the real Mercedes codes.
A dealer with a Star/DAS scanner can pull them for you but may charge the same as the iCarSoft costs (buck and a half).
Might call around a see if there is an Indy that can pull Mecesdes codes. Tell them it is the same as an '01-'03 (Facelift) SLK320 with 16 pin OBD connector.
Old Dec 16, 2017 | 03:21 PM
Raindem's Avatar
Erase with the ignition on. I've had this car for over a year and until now my scanner has worked fine to pull and erase codes. That's why I was wondering if it related to the mystery no start issue.
Old Dec 16, 2017 | 05:49 PM
Padgett's Avatar
Just for S&G try ignition ON, engine OFF, AC ON and try to erase. Am wondering if it is erasing then immediately resetting. My tool takes 30-40 seconds to erase codes.
AFAIR 410 is a generic for the secondary air pump.
Old Dec 16, 2017 | 09:15 PM
Most likely this is fractured solder in the path of the engine control relay on the RCM or a bad Engine Control Relay on the RCM. I'd pull it and send it to DJ and let him change the relay and go over the board's soldered connections.
Probably bad contact on the RCM in the SAI path - send it to DJ.
No clue. I don't reset codes, they go away in a few days after a few drive cycles if the issue is cleared up. If they persist, you have not fixed your problem.
Old Dec 18, 2017 | 11:20 AM
marlam's Avatar
I had the mystery no start issue a few months back and tried to sort it out myself, and then with a local garage (i.e. re-solder, crankshaft sensor, new battery etc). The problem still persisted, so I sent the RCM (from the UK) over to Tighed1 and he checked everything, replaced some bits and so far, no more problems. I think he is in your part of the country, so it should be easy to arrange and he has done a load of them.
Old Dec 18, 2017 | 02:14 PM
DJ ( tighed1 ) is just 30 miles down in Sierra Vista from you.
Send him an email at tighed1@hotmail.com and arrange a meet.
Old Dec 18, 2017 | 02:51 PM
Padgett's Avatar
Interesting. My sister has a Bisbee address but is on the west side of the hills and faces Hereford.
Old Dec 18, 2017 | 06:13 PM
tighed1's Avatar
Curt (RAINDEM)
We're like neighbors. Let's hook up and get 'er fixed!
DJ
Old Dec 19, 2017 | 07:05 AM
SRT Roadster and SRT Coupe and 6spd NA Coupe (1st BEGi Turbo XF)
DJ, you should change that to "first and last and only"
Just curious, how much did you end up paying Corky when it was all said and done ?
I understand if you would rather not respond.
Old Dec 19, 2017 | 01:47 PM
tighed1's Avatar
Think it was $3,200 when I dropped it off to him.
Why. Ya wanta buy it!?
Old Dec 19, 2017 | 04:16 PM
NO WAY JOSE !! Be too much of a nightmare every time I turned the key thinking "what if this sucker explodes, what would I do !"
You are the perfect person to own it, you can handle it.
tighed1
Jan 11, 2025 05:45 PM
ReignMan
Dec 13, 2015 07:34 AM
BltByKrmn
274
Jun 2, 2014 06:01 PM
blkXfire04
Oct 30, 2009 08:33 PM
kurtisberry
Oct 14, 2008 06:59 PM
