Mass air flow sensor problem
Old Jan 8, 2018 | 10:26 PM
Maggsj's Avatar
Default Mass air flow sensor problem
So I recently changed my mass air flow sensor because my check engine light was on. Changed the sensor and cleared the code then the check engine light came back on and the problem doesn’t seemed to be fixed. The problem is when I come to a complete stop it will shake and make sounds like it wants to die , sputters I guess. Any help ? Would greatly appreciate it.
Old Jan 8, 2018 | 11:53 PM
Steve Jr's Avatar
Default Re: Mass air flow sensor problem
When was the last time you changed your air filters? What code was thrown that made you change the MAF sensor? Have you checked the rubber at the filter housing to the throttle body?
Old Jan 9, 2018 | 08:16 AM
Maggsj's Avatar
I’ve had this car for about a year I don’t think the air filters have been changed. I took it to autozone and they scanned it and said it was the MAF sensor.
Old Jan 9, 2018 | 02:45 PM
Steve Jr's Avatar
Run back by AutoZone an have them check it again. This time write down the codes they give you. That will help us ,help you. How many miles on the car? Air filters should be changed every 15k. And who changed the sensor? You are not suppose to touch them with you fingers.
Old Jan 9, 2018 | 03:09 PM
Maggsj's Avatar
It’s at a shop now, waiting for a call back. Miles are about 108,000. My boyfriend changed the sensor and I told him about not touching it
Old Jan 9, 2018 | 03:38 PM
Steve Jr's Avatar
Good luck, let us know what they say...
Old Jan 9, 2018 | 05:53 PM
Maggsj's Avatar
The guy said he had to put in or re arrange the boot? The light is off for now. The guy said he doesn’t really know if it’ll come back on or not. So I really don’t know at this point. Drove fine the way home but not sure about tomorrow .
Old Jan 9, 2018 | 08:26 PM
deltacrossfirebob's Avatar
I clean mine with CRC MAF cleaner
Then use computer can air
Works great
Old Jan 9, 2018 | 08:36 PM
NeedsWings's Avatar
ensure that the valve cover hoses are not old/brittle/cracked as that would cause your issue and point to the MAF incorrectly.
PrisonGuy
19
Sep 7, 2023 05:56 AM
newaustinite
Jul 26, 2019 07:16 PM
X-fired
Jul 11, 2017 03:37 PM
Sterling57
Jun 16, 2014 09:25 PM
bluetb
Nov 19, 2012 05:55 PM
