auto box problem
Old Jan 10, 2018 | 03:06 AM
Motorman's Avatar
Default auto box problem
Hi
Hope you can help, just cant seem to crack this problem, intermittent lock in park when starting the car from cold, the usual several starts to get it to release, once the car has been running does not seem to be a problem, or is it that its that cold its frozen
Then found the secret slot for releasing the shift lock
Read up the previous notes from other owners, decided to buy a replacement brake switch, wrong switch delivered, now waiting for another, interesting it has a socket for two connectors but only one is present with only two wires
I expected to find two sets of connectors one for brake lights and one for auto lock
Any suggestions?
Old Jan 10, 2018 | 09:09 AM
Default Re: auto box problem
Originally Posted by Motorman
Hi
Any suggestions?
Have a look at the solenoid adjustment or operation. Maybe there is a poor connection to the brake switch.
File Type: pdf
Old Jan 10, 2018 | 10:07 AM
Dave is probably right, sluggish solenoid. I mean, it's cold nearly everywhere. If this happens on a 95F day, then I'd look elsewhere, but if it is cold-related, I'd think solenoid.
Old Jan 25, 2018 | 03:09 AM
Motorman's Avatar
Hi folks I solved the problem but though I would post up for reference
I ordered a replacement brake switch from flea bay, duly arrived but not until I was under the dash did I see it was wrong, switch supplied was for four wire set up, so duly returned switch and sourced the other one, arrived installed I didn't expect it to work as it was two wire but hey presto job done.
If I press the brake pedal I can just about hear the click of a relay under the dash so somewhere back up the loom is the park lock wiring so must have been the switch after all
What a pig to fit rolling about under the dash cracked a rib on the door cill as I attemted to extract myself from the ungodly position
Old Jan 25, 2018 | 08:24 AM
Sorry to hear about the cracked rib, you solved the problem that is the good thing.
Thanks for the reply, too many never bother to give any feedback.
Old Jan 25, 2018 | 12:36 PM
Padgett's Avatar
Think one element may be the dash indicator. If it comes up with the "P" when you turn the key on then it is communicating. If not it stays a blob. Second indicator is if you use the manual release and it slips into drive/revese it is talking. If a jerk it isn't. Final clue: if once in drive it shifts through the gears, it is communicating. If stays in 1st, it isn't.
Finally a bad shifter will probably set codes, faulty brake switch may not.
ps if I park with the top down, I put my hat over the shifter to keep water (rain, sprinklers...) out.
SteveB1
May 19, 2015 09:28 AM
+fireamx
Jul 27, 2010 06:24 AM
majkls xfire
Dec 13, 2007 11:47 AM
alonz4
May 16, 2007 01:19 PM
saldous
Jul 10, 2004 01:53 PM
