Headlight pointing too low
Old Mar 18, 2018 | 08:06 AM
GeorgeHirata's Avatar
Default Headlight pointing too low
Hi guys,
I have noticed that my headlights are pointing so low that I can barely see the light on the ground in front of me as I'm driving and looking over the bonnet.
Can anyone please advise how I can manually adjust the headlight cluster so that I can restore some vision by furthering the 'throw', as well as restoring my sanity?
Please help!
Old Mar 18, 2018 | 08:08 AM
Default Re: Head light pointing too low
Oh, if anyone has access to a maintenance PDF file, website, or YouTube clip that might help, please let me know of the URL so I can browse to it and check it out.
Old Mar 18, 2018 | 10:45 AM
DTMenace's Avatar
Originally Posted by GeorgeHirata
Hi guys,
Please help!
George
The link below contains all of the information you will ever need, related to your Crossfire, including a downloadable repair manual (PDF file).
Good Luck....
Dennis
DTMenace
Old Mar 18, 2018 | 03:32 PM
Mrmiata's Avatar
Old Mar 19, 2018 | 09:09 AM
zip439's Avatar
First Be sure the light bulb is in the socket correctly as in the picture in the post above by Mrmiata. Ninety percent of the time that will cure the problem. If you must adjust vertical beam of your headlights it is done by turning the **** located in the center of the light housing (between the two bulbs), turning counter clockwise will raise the beams. Adjustment horizontally is done by turning the **** located on the high beam side of the housing(closer to the vehicles center). Turning that **** counter clockwise will move the beam towards the right. Keep the beams pointed down and to the right. DO NOT point the beams straight ahead or too high as you will blind oncoming cars. The ***** may be covered with a cap which you will have to remove. Use an allen wrench to reach into the plastic tips of the ***** to turn them.
Old Mar 30, 2018 | 05:15 AM
Default Re: Headlight pointing too low
Thank you all so much for your assistance on this!!!
Old Apr 2, 2018 | 05:26 AM
Zip439, thanks again for this information.
Is it possible that you might be able to take a photo and detail which dia/**** I should be turning to raise the low-beam's height?
Thank you so much.
George H.
Old Apr 2, 2018 | 06:00 AM
KDW4Him's Avatar
If the adjuster was turned too far up and the threads popped the adjuster out of the socket. Simply turn clockwise slowly until you feel a pop now the adjuster is back in socket. If bulbs are seated properly turn counter clockwise until aimed properly.
Old Apr 2, 2018 | 11:07 AM
Mrmiata's Avatar
Old Apr 2, 2018 | 11:33 AM
Thank you so much.
George H.
The adjusting **** raises the high and low beams together. Get the bulbs located correctly before using the adjustment ****.
There is not much point in having the low beam correct with the high beam aimed at the stars.
Old Apr 4, 2018 | 03:21 PM
zip439's Avatar
Hay there Greg, Good picture thanks!
Old Apr 4, 2018 | 06:52 PM
Mrmiata's Avatar
The subject comes up so many times... and a picture is worth 1,000 words..
Old Apr 8, 2018 | 04:15 AM
And a portion of your knowledge is worth 1,000 dollars if I were to take the car to the store.
Thank you so much Mrmiata, sincerely appreciate it.
Old Apr 8, 2018 | 04:28 AM
Doh, my light cluster has an electric adjuster on it instead of the turn dial/****...
This is in turn restricting myself from adjusting the height above the 1/2 person setting...
Old Apr 28, 2018 | 08:49 AM
MrMiata, any chance you might know how to adjust the overall beam height for the electrically adjusted unit?
Old Apr 28, 2018 | 09:15 AM
Not to many on this forum have the electrically adjusted lights, UK, Oz, Europe(?)
Anyway, how is the high beam, too low or OK?
You have just mentioned this problem, is it a new problem or an old one?
Old Jun 18, 2018 | 09:23 PM
Hi onehundred80,
The high beam appears to be a little on the low side also. Hence, if there's a way to manually adjust the overall headlight cluster upwards, that would be most ideal.
Yes, the Crossie that I have is an Australian delivered 2004 model.
This is not a new post, but I just haven't been logged into the forum for a while...
Thank you.
2fastNstuff
May 31, 2018 06:32 AM
Tofudog90
Mar 4, 2018 10:43 AM
Lyn
24
Feb 22, 2018 04:07 PM
Jasbro
Jan 10, 2018 06:36 PM
