Clutch Pedal bounces
Old Apr 2, 2018 | 04:45 AM
tpellegr's Avatar
Unhappy Clutch Pedal bounces
When starting off on a hill the clutch pedal feels like it is bounces under My foot . If I just push the clutcn pedal down when the car is not moving and release the pedal I don't feel it bounce . I don't belive the throw out bearing or clutch is the problem . It olny seems to happen in first or second gear ? Wondering if there is a motor mount that is bad causing engine to twist ?
Thanks for Your thoughts Tom P.
Old Apr 2, 2018 | 08:24 AM
Speedy4x4's Avatar
Default Re: Clutch Pedal bounces
starting on a hillside only?
how steep of a hill?
smooth on flat ground from a stop?
just the pedal bounces and not the car?
car smooth?
Old Apr 3, 2018 | 01:15 PM
tpellegr's Avatar
Question Re: Clutch Pedal bounces
Starting on hill is when I feel it . AS long as You let the clutch up slowly !! Only feel the bounce in the clutch pedal not in the car . Don't feel the bounce on flat ground . Like I said in the first write up only feel the bounce when the engine is under a load like starting on a hill . Thats why I was wondering if a bad rear engine mount could be letting the engine twist ? But then this has a hydrolic clutch not a mechnical or linkage connected clutch .
I had two mechanic's at a Chrysley dealer test it yesterday and they could not feel the bounce . Told Me nothing is wrond with it . I will say after they tested it the bounce seemed not as noticable to Me when I drove it today . I was wondering if they road the clutch with the brake on and smothed out what ever was on the flywheel or clutch disc ?
almasyff8
Aug 23, 2011 04:42 PM
JimmySkullz
Aug 17, 2009 09:07 PM
Sdevante
Oct 20, 2008 06:55 AM
dec1184
Nov 21, 2007 04:16 AM
landho
Jun 6, 2004 08:13 PM
