Srt 6 '05 throttle lag
Old Apr 4, 2018 | 10:40 PM
Moehawash's Avatar
Default Srt 6 '05 throttle lag
I have a problem with the throttle delay I guess. I push down the accelorator and it takes about 3 seconds for it to accelorate and it lags. I don't know how much more too explain. I've done the reset with the gas pedal and it still came back. Can someone please help? Much appreciated.
Old Apr 5, 2018 | 09:50 AM
zip439's Avatar
Default Re: Srt 6 05 throttle lag
That is normal, but three seconds sounds a bit too much. You can get a "sprint booster" which will correct that, but I would not waste the money if you are going to make any additional performance modifications. When you complete the mods you will want to "tune" your car. That will eliminate the throttle lag.
If you are only concerned with the lag and have no desire to mess with anything else under the hood then the sprint booster is the way to go. Have fun, but be careful.
Old Apr 5, 2018 | 10:34 AM
have you tried this it free thanks to onehundered:
https://www.crossfireforum.org/forum...ttle-reset.pdf
Old Apr 5, 2018 | 11:01 AM
NeedsWings's Avatar
sounds like a failing throttle body or gas pedal, you may get lucky on a throttle recalibration.
when you say it came back, does that mean it solved the issue temporarily?
Old Apr 9, 2018 | 04:10 PM
Moehawash's Avatar
I tried that and it worked but then after a a while it went back to how it was.
Old Apr 9, 2018 | 04:11 PM
Moehawash's Avatar
Exactly that. It was only a temporary fix.
BoB Fenn
22
Mar 8, 2018 04:29 PM
DZL
Mar 4, 2018 03:54 PM
ChuckNorris
Jul 2, 2009 10:30 AM
Cal_Cobra
Sep 22, 2008 04:53 PM
tom2112
Apr 28, 2008 06:14 AM
