power problem?
Old Apr 11, 2018 | 07:26 PM
crazyfred's Avatar
Default power problem?
Hi Everybody
I have an issue with my 05 roadster. When I depress the gas pedal until it hits the button on the bottom of the pedal's travel and let it all the way back to top, depressing the pedal again, it's like it's not working.
Slowly depressing the pedal will result in a very slow up tick in rpm's. Engine will idle and does not die.
Did the throttle reset twice, no joy. If you shut down the car and restart, everything is back to normal until you fully depress throttle until you feel the button depress.
Any idea's? Just started this. Car has been stored since last November. Everything is normal until you do a to the floor gas pedal push.
And what is that button at the bottom of the pedal travel do?
Thanks in advance for any help you can offer.
Fred
Old Apr 17, 2018 | 06:16 PM
crazyfred's Avatar
Default Re: power problem?
Wow, no electrical guru's out there? Or maybe it's mechanical. Looked around and could not find a similar issue. I would like to get this fixed before it gets warm out.
Could be awhile for spring, since its 30 degrees and snowing now.
Thanks for helping me out
Fred
Old Apr 18, 2018 | 09:49 AM
I'd suspect a bad pedal sensor - the pedal and sensors are part of an assembly I believe, change the whole thing out.
It could be a problem in the ECU but I doubt it. Any Check Engine light? I'd think a bad pedal position sensor would illuminate the CEL, but perhaps not.
My last two have been manuals, life is easier with the manuals as we don't have the kick-down switch.
Old Apr 24, 2018 | 04:49 PM
crazyfred's Avatar
Pedal assembly ordered. Will update when it is installed>
Thanks
Fred
Old Apr 27, 2018 | 10:46 PM
crazyfred's Avatar
Pedal assembly installed. Problem solved. Thanks for the advice.
Fred
Old Apr 27, 2018 | 11:29 PM
Fred
Thanks for the reply, many do not come back with the solution and a thank you.
Good news.
Old Apr 28, 2018 | 01:05 PM
Yes, a big THANKS for coming back to tell us how it went.
This way, your cry for help becomes 'help' to someone else later on...
Desert_srt
Nov 3, 2012 02:53 PM
maxcichon
Other Vehicles
Jun 18, 2012 02:07 PM
boboridesbmx
21
Feb 24, 2012 06:44 PM
chris4490
Nov 13, 2008 07:49 AM
wolverine1988
May 30, 2005 09:21 AM
