Wheel Bearing
Old Apr 14, 2018 | 06:21 PM
droopaloop's Avatar
Default Wheel Bearing
So I'm replacing my wheel bearing. everything is disconnected and the half shaft is out. I cant get the half shaft out of wheel hub. Do I pry the wheel hub off or do I hammer out the half shaft?
Old Apr 14, 2018 | 06:30 PM
Default Re: Wheel Bearing
book says a special tool is required :
Old Apr 14, 2018 | 06:39 PM
droopaloop's Avatar
ok, but i think I'm stuck on the step before removing the bearing, as the half shaft is still in the hub. Unless that tool will remove the bearing and or hub with the half shaft still in the hub.
Old Apr 14, 2018 | 06:44 PM
droopaloop's Avatar
I think i found the answer not the same car but same parts it looks like. @14:10
Old Apr 15, 2018 | 02:34 PM
Originally Posted by droopaloop
https://www.youtube.com/watch?v=SYqAVPX1Qqo
Quite a lot of information on that page, also reference pages too. Good source?
Old Apr 15, 2018 | 05:01 PM
Miller tool part number may be wrong, see this post. CLICK
Miller tool list for the Crossfire CLICK, you must use the password 'crossfire'
Old Apr 15, 2018 | 08:01 PM
Generally I use a dead-blow hammer. Or being very careful, a hammer and brass punch. The bearing in the video is not the same as the Crossfire suspension. The video shows a hub that bolts in. The Crossfire bearing must be pressed in.
James
Old Apr 16, 2018 | 07:28 PM
droopaloop's Avatar
yea, different suspension but same half shaft. The half shaft was stuck in the wheel hub on my car. Just for future references of this post: the point of it was removing the half shaft not changing the wheel bearing. I ended up having to go to a shop to have the half shaft pressed out.
rakoom2002
Oct 3, 2014 07:15 PM
rakoom2002
Jul 30, 2012 03:41 AM
rakoom2002
Dec 8, 2010 06:04 AM
vipr1ab
Racing
Oct 23, 2010 11:25 AM
James1549
Oct 20, 2009 04:47 PM
