Racing The place to talk about autocrossing, road and drag racing.
Solo II - Failed tech inspection for loose wheel bearing
Old Oct 10, 2010 | 12:28 PM
vipr1ab's Avatar
Question Solo II - Failed tech inspection for loose wheel bearing
Took the car to its first event to have some fun but it failed inspection because of play in the front passenger wheel. There are no noises coming from the wheel, and the wheel spins smoothly by hand with no binding. My first thought was the hub bolt is a little loose, but after doing some research, according to the service manual, this minor amount of play is normal. Checking both wheels, I confirmed there is play in both of them. The side that failed appears to be more noticeable, however. I'm all but convinced there is nothing wrong. How do I convince the inspectors of this if they aren't familiar with it? I don't want to waste time fixing a problem that doesn't exist, nor do I want to waste half my day going to another event only to have a hard time getting it through tech.
Old Oct 23, 2010 | 10:59 AM
Wedge's Avatar
Default Re: Solo II - Failed tech inspection for loose wheel bearing
Sorry to hear about it. I've never had a problem passing tech. Maybe you've got a bit too much play. GL
Old Oct 23, 2010 | 11:25 AM
I have more play in the front wheels of the roadster than does the coupe. I haven't had time to get under there to see what is what...but, some play is normal....but, I believe the roadster has a problem...she doesn't steer as tight as she once did....
xfClifford
Mar 3, 2021 04:52 PM
xfireohio
Jul 20, 2020 12:03 AM
cdcrone123
27
Sep 24, 2015 11:28 AM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
cdcrone123
Aug 4, 2015 06:37 PM
