Switched Power for VDO
Old Apr 29, 2018 | 11:04 AM
DHS's Avatar
DHS
Exclamation Switched Power for VDO
OK, got the underpanel out, gages wired and will start with oil temp. I have one power wire for the two gauges, where is a good place to get switched power? Will run the sending unit wires (2) out to the engine through a port on the left side fuse box.
Found a bunch of broken tabs where the P.O. had put in some stereo, mine now has the stock one in, he must of kept the other, did a s**t job under the dash!
Thanks
Dan
Old Apr 29, 2018 | 12:05 PM
Default Re: Switched Power for VDO
Since you are going out through the fuse box anyway, you can find switched power on one of the post connections at the rear, you must remove both plastic fuse box covers to see them.
Old Apr 29, 2018 | 02:31 PM
DHS's Avatar
DHS
Talking Re: Switched Power for VDO
Perfect, two are switched!
Thanks
Dan
bucketlisted
Jul 13, 2016 11:11 AM
Romio
Jul 12, 2009 06:21 PM
jackei
Nov 25, 2008 03:03 PM
mrphotoman
Nov 21, 2008 05:06 AM
sonoronos
Dec 12, 2007 03:36 PM
