View Poll Results: Which side of the window button makes the windows go down
Front
25.00%
Rear
27
75.00%
Voters: 36. You may not vote on this poll
Are my window switched backwards?
Old Jun 19, 2009 | 11:40 AM
Romio's Avatar
Default Are my window switched backwards?
I have an 04, and when I press for forward part of the window switch, the windows go down, and when I press the back end they go up. I test drove a SRT a few days ago and his was opposite then mine. Was there a switch from 04 to 05, or mine just backwards?
Old Jun 19, 2009 | 02:04 PM
Kurts's Avatar
Default Re: Are my window switched backwards?
Romio, my '04 is exactly the same & completely opposite from my SRT. Gets confusing if I switch between cars often..........
Old Jun 19, 2009 | 02:09 PM
rcompart's Avatar
This is a really quick fix on the manuals and somewhat more time consuming on the autos but all you have to do is remove the shifter surround panel and using a butterknife or other thin sturdy tool to slip in between the tabs that hold the buttons in. Start on one side and get that tab popped out and then keepign slight pressure on the face of the switch, do the same for the other tab. After it's out, you can jsut slide your finger nail under the middle of the switch where it hinges and pop the cover off. Flip it around, verify taht it's corerct and reinstall. Hope this helps.
Old Jun 19, 2009 | 11:24 PM
My 2004 is the opposite:
Blue is UP
Red is DOWN
And no the colored dots are actually not on the car ...LOL
Old Jun 19, 2009 | 11:57 PM
I think it is a Benz thing. I had two '90 420 SEL sedans. The switches were opposite.
Best engineered cars in the world, right?
maybe it's that union thing. curious.
roadster with a stick
Old Jun 20, 2009 | 12:58 AM
dwightdmagee's Avatar
Banned
Just curious:
Both buttons, whether flipped around or not, should go to 'automatic down' once pushed beyond intitial resistance and into the detent. Do both your '04 and SRT buttons do this?
Don't tell me that one of them goes into 'automatic up'.
Old Jun 20, 2009 | 01:11 AM
rcompart's Avatar
Originally Posted by dwightdmagee
Just curious:
The physical orientation of the switch has nothing to do with the function of auto down. If they are flipped around, it's because someone put the caps on upside down. I'm sure it was a day shift/night shift deal where the guy popping the caps on at one time was doing it opposite to that of the other guy and after they caught the mistake, it was easier to just sort them out as they were installed and make sure the car had a matching set and not one front-down/back-up and front-up/back-down. BTW, no way to make these do auto up. tried and failed miserably having to replace both window switches so the LED intensity was the same as well as the control module because I fried it. It's a resistance thing and let me tell you, you can make some pretty weird **** happen by varying the resistance to ground on the signal wire.
Old Jun 20, 2009 | 10:11 AM
Kurts's Avatar
Just curious:
Yup!
On either car the auto-down feature works just fine!
And, IMO, it's not worth the hassle to yank the covers off of the console & flip the switches around. All it takes is just one "whoops, wrong car" & we're pretty squared-away as to which direction to push ze button.
Old Jul 12, 2009 | 06:21 PM
You have an Australian version, they work properly down under.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
