Fuse info
Old Apr 30, 2018 | 07:46 PM
DHS's Avatar
DHS
Default Fuse info
I have two 05 coupes, a SRT and NA, the SRT has yellow card in the fuse box cover with the info on each fuse. My NA does not have one, since it is the base model my guess is it is different than the SRT. Could some one with a base car make a photostat of theirs and send it so I can have one for the car?
Thanks
Dan
Old Apr 30, 2018 | 09:23 PM
Default Re: Fuse info
Just to be clear, is your 05 "base" an actual Base model or a Limited? Cause there are differences even between the Base and Limited.
Old Apr 30, 2018 | 11:33 PM
This is a scan of the fuse box label on my SRT.
Note that some fuses are in brackets and they are not on the SRT, does one label cover all years or just the year 2005 fuse positions. Checking with the owners manuals should answer this question.
This actual scan could be modified to show any changes using Photo Shop or a similar program.
Old May 1, 2018 | 07:42 AM
DHS's Avatar
DHS
Not sure if the NA is base or limited, all black trim, stock wheels, cloth seats, six speed stick. I have the SRT one so need to see one out of a NA to see if they are different.
Old May 1, 2018 | 07:55 AM
Steve Jr's Avatar
My thought would be , they are the same. Except for the seat relays.Trim an interior is where the differences are. Black trim suggests base. SE came out with different wheels than base or limited.
Old May 1, 2018 | 07:58 AM
I realize that, my point was is my one was similar or the same as others because of the fuses that were in brackets.
Why put a SRT fuse in brackets when it actually came from an SRT, and fuses for an NA where also in brackets, get let? Convertibles may be different again.
Maybe from 2005 on all labels might have been the same if not PhotoShop could make it slightly different.
Sometime back a member with an SRT that was missing this label printed this photo for his car.
Old May 1, 2018 | 08:13 AM
Steve Jr's Avatar
180 is correct , the only difference is slot 16 an 20 are swapped. 16 is wiper motor an 20 is spoiler motor, then 7 is the rearview mirror on mine. But you wont have to worry about that...
Seat relays are not on the base cars but oddly on this label they are not in brackets while the garage door opener is.
Old May 2, 2018 | 04:59 PM
DHS's Avatar
DHS
Talking Re: Fuse info
Well I was able to make a PDF file and then make two big copies and two smaller. Went to Kinkos and laminated all four, the big one for the glove box and the small ones to the fuse box, worked out nice!
Thanks
Dan
Jesticle
May 20, 2011 02:42 PM
vet4scuba
Oct 27, 2005 07:11 AM
respdoc
Aug 17, 2005 02:45 AM
MAYAman
Jun 27, 2005 07:26 PM
Wayne1992
Mar 7, 2005 09:30 PM
