Change TB
Old May 5, 2018 | 12:30 PM
DHS's Avatar
DHS
Default Change TB
I asked on the coupe thread but will post here also. On a SRT I got a spare TB and sent it to MAXBORE who punched it out to a 78mm bore. I put it on this mourning, o-ring in place and the hose to the TB hooked up. Car ran terrible so I put the stock one back on, still ran bad but after a trip around the block it is smooth, still have a check engine light on.
Going through the threads I see some who put the 75mm on the NA’s they would run rough for a while then smooth out, should I try that? Will the CEL go away or do I have to get it turned off?
Thanks
Dan
05’s SRT and NA coupes.
Old May 5, 2018 | 02:26 PM
Default Re: Change TB
I have also read about the NA's running rought for a while, I have put 74mm on mine and 1 other, neither ran rough at all. The CEL may reset itself after a drive cycle, but you can always reset it yourself.
helm
Mar 27, 2007 08:44 PM
Extensive
Nov 22, 2006 09:34 PM
chuckhaze
Mar 31, 2004 03:36 PM
helm
Dec 30, 2003 02:03 PM
X-fired
Jul 29, 2003 01:38 PM
