Power loss and IC pump
Old Jul 19, 2018 | 09:51 AM
srt6exy's Avatar
Default Power loss and IC pump
My 05 srt6 has 67k miles currently. It runs just fine when I first start it up but after I do a few pulls it decides to not engage the supercharger. If I go real easy itll kick on eventually for a pull or two then kick off again. I have read several posts and threads and everyone immediately says to replace the ic pump. I just replaced my belt because i was getting some build up and there were a couple small cracks in it but it does not appear to be slipping now. I have also checked my fuses and my AIT sensor and all appears to be good. Is there anything else I can check before buying a new IC pump? or is there a way to actually check the pump itself by jump starting it somehow? Also if anyone knows where to get a good deal on a new pump if thats what I need I was thinking the updated bosch system. Thanks in advance!
Old Jul 19, 2018 | 10:24 AM
NeedsWings's Avatar
Default Re: Power loss and IC pump
start the car, leave in park, rev to 2k, let it go back to idle. put your hand on the IC pump and feel if it is running.
or use a obd2 scan gauge and look at the AIT
Old Jul 19, 2018 | 11:36 AM
I think the pump motor could be running but the impeller may me broken apart and not turning.
See this post. CLICK
Old Jul 19, 2018 | 03:43 PM
srt6exy's Avatar
Thanks I will try this as soon as I get home from work!
Old Jul 20, 2018 | 04:49 PM
The motor may turn but not the impeller. The motor runs for years but the impeller was a poor design and breaks apart. The new pump part number ends in 10, the rest of the number is the same.
You can get a new pump from FCP Euro or NeedsWings among others.
Old Jul 21, 2018 | 02:24 AM
srt6exy's Avatar
Thanks man still haven't had time to get in the garage been workin 12hour days.
kingtj
Oct 24, 2015 07:32 AM
ModlessG
Jun 9, 2011 08:11 AM
ohnoesaz
Sep 18, 2008 12:13 AM
forever35
May 1, 2008 11:21 AM
tony sortino
Jun 19, 2006 05:35 PM
