Help with ESP/BAS light and codes
Old Jul 30, 2018 | 08:43 PM
Joef89's Avatar
Default Help with ESP/BAS light and codes
so ive been having nothing but challenges with my crossfire srt.
So the issues,
When driving after about 45 min the BAS/ESP Light comes on and the super charger looses power almost like its put into a limp mode.
Thought maybe IC pump or the IAT were to high. replaced the intercooler pump, then the water pump. Added a coolant separation kit. Change the IAT sensor, the cam sensor, the RCM.
Problem still persists.
So finally broke down and bought a scanner.
First the MB2 by icarsoft. was able to pull codes if i put it in as a mercades slk32 amg however was not able to clear them even if i tried.
The next day after attempting to clear codes the ABS light came on when i started the car. Wasnt able to pull the ABS codes with the MB2 so I retuned it.
Scanner 2 well actually 4 if you count the two cheap ones i owned before this.
Ordered an Altel MD808 Pro. (reached out to altel directly and they assured me this scanner would work)
Well go figure it didnt.
wasnt able to pull it up as a crossfire, it couldnt even access the modules.
then again connected as a slk and could pull the codes, but not the abs, couldnt clear the codes either.
Attached below are the codes.
c1024, c1174, c1410, p207c,P2314, P2318
StanTheEdge
May 21, 2016 02:38 PM
AlexParra
Dec 9, 2013 02:10 AM
blackoutken
Jan 25, 2012 11:21 AM
new2crossfire04
Dec 4, 2010 05:21 PM
