Lock and siren troubleshooting. Need help!
Old Oct 7, 2018 | 07:45 PM
summerstar's Avatar
Default Lock and siren troubleshooting. Need help!
Hello.
my crossfire srt started acting wierd and alram keeps going off.
i’ve replaced siren to brand new, but problem won’t solve.
i’ve realized when i lock crossfire with key on driver side, passenger and trunk is not locking.
can anyone tell me, what’s wrong with my SRT?!?
Old Oct 7, 2018 | 10:16 PM
Default Re: Lock and siren troubleshooting. Need help!
Originally Posted by summerstar
Hello.
I can say with 100% accuracy, it sounds like water in the lower trunk/hatch cavity. Check there and hopefully water damage didn't destroy the module there!
Old Oct 9, 2018 | 03:32 PM
summerstar's Avatar
Thanks for relpy.
what should i do,if any signs of water damage is found?!
i havent checked it yet
Old Oct 10, 2018 | 04:41 PM
Can you lock all the doors using the fob?
Does the switch on the dash lock all doors?
The alarm issue looks like it was a false alarm.
It looks like the pump in the trunk is damaged maybe it will dry out, normally they are ruined.
If you have to get a pump, get one with all the plugs with it as your plugs may be ruined by corrosion.
These pumps are not cheap.
Old Oct 10, 2018 | 09:55 PM
summerstar's Avatar
hi
dash lock can lock all doors and trunk.
remote lock and unlock is working,but lock and unlock by actual key on driver side won’t lock or unlock any doors except driver side door.
alram going off randomly when door is locked.
Old Oct 11, 2018 | 10:04 AM
hi
The drivers door has a switch on the lock cylinder this should somehow tell the pump in the trunk (CLP/SSM) to operate and lock the passenger door, the gas cap door, the hatch/trunk lid and the console lid on the roadster.
Old Oct 13, 2018 | 04:34 PM
summerstar's Avatar
hi. I dig into lower trunk area today.
i found lust on lower body panel probably caused with moisture, but no sign of water on module it self
Old Oct 13, 2018 | 06:11 PM
Lust is often found on the lower body.
Old Oct 15, 2018 | 09:51 PM
summerstar's Avatar
hello
i’ve upload video of my central lock module on youtube.
wishing.. hopefully to get help on this forum.
i believe module kind of sound heistating when locking by remote control. Can leak or lack of pressure on yellop line triggering siren to go off??
Old Oct 16, 2018 | 12:35 AM
hello
https://youtu.be/zK9bdOXHEic
I do not think so.
The siren can sound when a sensor shorts out somehow.
Old Oct 16, 2018 | 01:30 AM
summerstar's Avatar
I do not think so.
Hello, sir.
can you let me know which sensors could triger siren?
until now. I’ve replaced siren to brand new, replace fuse 9 and other 2 fuses people mentioning that it’s related to siren.
it may not right... but i think siren is not going off randomly for two days, when i replace fuse #9.
Also, when i first replaced siren to brand new and replace inner battey on old siren, they did not go off for 4-5days..
could it be electrical problem that siren is not getting enough recharge?
i drove about 120 miles per week, voltage on my car battery reading at 13.8 volt with engine running.
Old Oct 16, 2018 | 10:07 AM
Hello, sir.
There are sensors in latches and locks. You said you had changed the siren and there was no change, now you say there was and mention two sirens, I am now confused as the story changes. An old sir3n can fail when the battery inside leaks and messes the circuit board.
What gives?
Old Oct 16, 2018 | 12:41 PM
summerstar's Avatar
What gives?
hello. I replaced battery in old siren but no success.
so I gave another try with brand new siren, which kept my car quit for few days and siren go off agian.
zalsaigh
Apr 28, 2017 01:24 PM
GraphiteGhost
Sep 10, 2013 10:40 AM
firedUPgirl04
Aug 28, 2013 11:28 AM
dinasrt
Racing
Apr 23, 2012 06:43 PM
workindev
Mar 9, 2009 08:55 PM
