Getting off a Bird Crap Mark
Old May 20, 2005 | 09:54 PM
Marc B. Mankuta's Avatar
Default Getting off a Bird Crap Mark
Any suggestions as to getting off the mark made from bird droppings. Couldn't get home to clean it for a couple of hours and now it seems to have left an underlying mark. No visible mark from 5' away but if you get close enough you see a mark in the paint. Shine is still there but so is the mark. Any help is appreciated.
Old May 20, 2005 | 11:09 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Getting off a Bird Crap Mark
begin with a non-abrasive polish (3M or meguairs) product applied by hand.
if this doesn't work...the surface may need a high speed buffing or wet sanding.
Old May 20, 2005 | 11:20 PM
Gene12's Avatar
This suggestion won’t help this time around but maybe next time. I carry a couple of small rags in the empty compartment where the air compressor is stored for small emergencies such as what you described. Add water and problem solved before it does any damage.
Good luck getting the mark off, it shouldn’t be that hard.
Old May 20, 2005 | 11:57 PM
golfdude's Avatar
Use a claybar and car wash soap (or claybar lubricant) to remove particles imbedded into a paint surface. After that, wash the area like normal to remove the natural claybar residue.
Old May 21, 2005 | 12:01 AM
Dan Root's Avatar
Banned
First find the bird...pull out all it's feathers but don't kill it because you want it to tell it's fellow bird buddies not to crap on Crossfires!!!
Then if you didn't have some cleaner in your Crossfire don't tell anyone!
Spit as much saliva you can on it and wipe with clean shirt or sock!!!
Old May 21, 2005 | 03:24 PM
Like your suggestions. Thanks for the advice.
Old May 23, 2005 | 12:18 PM
Aero Blue's Avatar
Lightbulb Re: Getting off a Bird Crap Mark
Sorry to hear about this, but here what I'd try first. After cleaning the area off real good, try some Mequiars Scratch-X. This should lighten it up a bit, if not remove it, but if that doesn't work, your going to want to try some "non-abrasive" paint cleaner. Finally I know this after the fact, but this is why you should have a couple coats of wax on your car, just in cases like this. Good luck to you.
Old May 25, 2005 | 06:15 PM
X-LR8's Avatar
Wax = no matter how many coats will not protect against the horrid bird stuff (especially if they eat berries) for long = since the acids will eat through the wax and into the paint! Time is of the essence in this unruly equation = carry some club soda along to remove the first site of the stuff = if need be: place your thumb over the opening and shake the bottle well for some forceful spray action to aid in initial removal, then spray some detailing spray (meguiars makes a good one) on the area and then wipe clean with a microfiber towel! If left with a stain = you will need to polish it out preferably with a porter cable 7424 polisher and a good polish! Read all about it here ... and good luck.
http://www.autopia-carcare.com/inf-pc7424.html
Old May 25, 2005 | 07:29 PM
golfdude's Avatar
Ahh, someone who actually uses autopia.org!
Old May 25, 2005 | 09:41 PM
Dan Root's Avatar
Banned
Talking Re: Getting off a Bird Crap Mark
Yeah or just spit and wipe if you don't.
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 25, 2015 07:46 AM
livefreeordie
Sep 22, 2015 08:13 PM
