Battery specs?
Old Feb 3, 2019 | 01:24 AM
Cotyt94's Avatar
Default Battery specs?
Just bought meds black limited. Things a beast. needs a new battery. is there a higher power battery I can put in it? to compensate for the phantom battery drain problem while I figure it out. also would like to save some power for some subs in the future.
Old Feb 3, 2019 | 12:52 PM
Default Re: Battery specs?
NO. Two tihngs:
1) No, you are not going to find a higher capacity battery - not such that it compensates for a problem like that.
2) Always remember, lead-acid type storage batteries are designed to provide 300 or more amps for a few seconds to start the car. THey are NOT happy when partly, slowly, discharged often - that will age the battery in no time.
2A) You don't need a bigger battery for "subs", the alternator is a 120 amp output version - at idle it can provide almost 1/2 it's output and at 1500 engine rpm, it can produce all 120 amps. Again, if you are going to sit with the engine shut off and audio system on, just know that it shortens battery life (unless you run a marine battery - which can provide 300 amps AND can tolerate partial discharge).
To find where your current is going, get an ammeter (or DVM), open the ground cable connection, and put the meter in series. Start pulling fuses until you find where it's going. That is the ONLY way to find it without spending tons of time.
Old Feb 3, 2019 | 08:10 PM
Cotyt94's Avatar
Thanks for the info! I guess im still wondering what are the specs of the battery you are running in your own crossfire
Old Feb 3, 2019 | 08:40 PM
You want a group 48 battery rated around 700 cca."
Goldwing
Jun 21, 2010 03:51 PM
ProjectMayhem
Jul 14, 2008 07:16 PM
XFiring
23
Sep 19, 2007 09:30 AM
EJWIII
Sep 14, 2005 02:54 AM
HDDP
Jul 24, 2004 06:11 PM
