Backup lights
Old Jun 20, 2019 | 04:19 PM
Default Backup lights
My backup lights don't work. All other lights do. Any thoughts? Is there a switch in the shifter that could be bad?
Old Jun 20, 2019 | 05:55 PM
Default Re: Backup lights
Either fuse 4, backup switch if manual, or shifter assy if automatic :
Old Jun 20, 2019 | 06:05 PM
I checked the bulbs, they are fine.
Old Jun 21, 2019 | 10:21 AM
Thanks ALA-XFIRE, now the directionals quit, are the connected in any way or a different issue?
Old Jun 21, 2019 | 10:36 AM
1. Fuse #4 in the illumination control module ( headlight switch )
2. multifunction switch ( the turn signal stalk )
3. The light switch itself
Do the directionals flash with the hazard button ?
Old Jun 21, 2019 | 12:28 PM
The directionals flash with the Hazard button?
Old Jun 21, 2019 | 05:53 PM
Now sometimes they work and sometimes they don't. Does it sound like the multifunction switch?
Old Jun 21, 2019 | 05:56 PM
Sounds like sumpins loose somewhere, and the stalk is a good candidate.
Old Jun 21, 2019 | 06:18 PM
Thank you sir!!!
Old Jun 21, 2019 | 11:39 PM
Originally Posted by ZERACER
Thank you sir!!!
Have you had the ICM out or played with it somehow? I caused a problem on my old NA by not connecting a plug securely and some lights did not come on.
Pushing the plug on tight solved the problem. You could try another ICM if you can lay your hands on one, they are cheaper than a multifunction switch.
Old Jun 22, 2019 | 10:30 AM
I'll try removing it and checking the connections.
Old Jun 22, 2019 | 06:26 PM
No need to remove it, just drop the panel under the dash and it comes down with it.
The instructions to remove the panel are in the Sticky Key Fix PDF. Print it out and follow the instructions.
Old Jun 22, 2019 | 07:41 PM
Again, I thank you. You guys are always there to help.
Old Jun 29, 2019 | 02:44 PM
Well, the directionals were a loose plug to the headlight switch (ECM). Now if I can figure out how to trouble shoot the backup lights? I do have a bulb out warning light when I turn on the headlights.
corfire
May 13, 2015 11:47 AM
waldig
Jan 26, 2013 05:45 PM
EOLJR
Nov 20, 2009 05:37 PM
Black Diamond
Mar 21, 2007 11:49 AM
FirebaseD
Jan 5, 2006 12:54 AM
