license plate light
Old Sep 16, 2019 | 02:45 PM
cg80's Avatar
Default license plate light
My left license platelight is not working...right one is...possivble problem?...changed bulb.....not working...replaced unit...not working...took left one and placed in right...not working...took off panel...only see two wires and socket...any ideas as to the problem?...thanks
Old Sep 16, 2019 | 03:53 PM
zip439's Avatar
Default Re: license plate light
1 Carl from your post quote " Took left one and placed in right ... not working"
I wouldn't expect the bad bulb to work; Try putting the right bulb into the left. ( I'm sure you did, just reading what you wrote)
2 Break out the volt meter and check for power 12v DC.
3 Clean the bulb sockets contacts
ONLY three weeks to the Dragon
Old Sep 17, 2019 | 10:50 AM
cg80's Avatar
Hi bro...glad u got your car fixed.....hope to see u there... I have installed after market sockets (led equipped) nothing seems to work on that side..???
Old Sep 17, 2019 | 12:25 PM
LED bulbs only work with the positive and negative wires correctly attached, if the wires are switched the bulb does not light up.
onehundred80
Jan 1, 2015 03:12 PM
Avantidude
Aug 8, 2014 10:23 PM
devildog1967
Apr 23, 2013 08:28 PM
smokey847
Nov 18, 2012 05:05 PM
blwnstang02
20
Jan 2, 2012 03:50 PM
